!965 Pontiac P-8 Rear Drum hardware and rear shock mounting studs.
Looking for a left and right set of rear drum hardware. The metal brackets, one is the auto adjuster and the upper bracket that goes between the shoes. Also looking the brake cylinder pins, the go in the end of the cylinder. Both sides needed. Needing the rear shock mounting studs the mount on the rear end of the differential. Also a set of rear drum adjusters.
