Bowl Gaskets
Any ideal what the part number might be for just the Rochester 2G bowl gaskets is? (at a parts store)
Cost? Carb kit, I have, had a couple of the Bowl gaskets robbed from it when I bought it on the board. Tom V. |
Bowl to air horn? Can the parts store cross reference from GM numbers? Try 7021007, 7021008 or maybe 7008600. They did vary some over the years and depending on application of the 2G.
pfilean, what do the P/Ns you provided apply to (year, engine)?
...because if those are not '62 2GC and you have the OEM number for THAT, please share it. I need a new airhorn gasket for my Safari's carb... |
Any of you that need airhorn gaskets, base gaskets, or other Rochester gaskets, let me know. I buy them in bulk and can help you out at minimal cost. Just let me know the year and carb arrangement on your engine.
The '62 Safari single two barrel uses the same airhorn gasket as the '59-;66 Tripower end carbs. I have about 100 of those at $2.00 each plus shipping. |
Here are the gasket number such as they are.
But by the time you get a counter guy to cross reference the numbers and see if he can get them I'm sure Dick has a better offer. And the increased volume should keep him in good favor with his supplier. Go Dick. |
