Need part # for 1972 fuel pump
Anybody know the part number for a 1972 455-HO fuel pump? Looking for an original AC pump if anyone has one.
That part number was used on ALL 1971-1972 A-body and G-body 4V engines, by the way. |
Will also occasionally run across the alum body stamped 40863 on older AIRCO's. the plating and bottom structure will be the exact same....they also ended up on Bonnevilles and Grandvilles. Firebird 4bbl was different.
