Q jet info for all, power piston spring rating
Last night after nearly giving up on the web search for this info,( which is info I use to have stached away somewhere) I though I would post IT up here for folks.
This is the Rocchester part number, but far more important, the HG vacuum rating at which they start to let the Carbs power system come off the idle circuit. 7037734 14.4" 7032758 11.5" 7037305 10.6" 7036019 8.4" 7029922 7.3" 7037851 6.3" I have somewhere a list of Carb numbers that tells which Carbs came fitted with some of these common numbers, if I turn that up I will post it also. |
that's good thanks. do you have springe lengths for these spring numbers.
turns count? spring force? or where do i ref these part numbers into such specs? |
No, but I think there may have been a color code involved also, but once a spring gets 40 + years old in regards to used carbs I do not think that would be of much use anyway!
Turns count? All things being = the less turns, the stiffer the spring and the higher the HG number will be. Spring force? Don`t need it man, thats what the HG rating is for. |
STEVE I HAVAN,T RUN A POWER PISTON & METERING RODS,IN 5 YRS IN MY gto, best secret i ever did so far. never a issue.
7037734 14-4" 7032758 11-5" 7037305 (black/brown) 10-6" 7036019 (orange) 8-4" 7029922 (blue) 7-3" 7037851 (yellow) 6-3" giving the range were the spring operates. I can add 7029529 (purple) 12-5" to the list. |
Ah,thanks!
