trans swap
What parts could i use from a late 70's firebird 4 speed to convert my 70 lemans to a 4 speed? Would everything work but the clutch pedal and driveshaft?
the z bar is different on the lemans/ gto bodies from a birds.
clutch/ pressure plate, bell house should all bolt up if it is an earlier bird. flywheel depends on what motors are being used. around 77-78 they changed the size of the rear of the crank, so earlier flywheels don't interchange. |
I was just thinking of a guy that lives about an hour from here. He's where i bought my motor from. He had around 20 firebirds from the mid to late 70's sitting in his yard and some were 4 speeds. Its been several years since i've been by his place, but i doubt he's gotten rid of much.
