1968 16 Head E208
Need only one 1968 16 Head date code E208, untouched, magnafluxed certified prefered.
I have a D178
Sorry, I need the correct date code.
Still Need one 1968 16 head date code E208.
Still would like to find #16 Head Date Code E208, Untouched.
Bump, Still looking for 1968 #16 Head Date Code E208.
Dr. Schiffer, of course I don't know your reason for exactly the same date,but there are thousands/thousands/millions / that are original cars,where the date codes are close but not the same day.They put in what was asked for on the build sheet,etc,and grabbed what was available,I have a 65 GTO with original,and the dates are a few days apart.
Now,maybe your car originally came with same date coded #16 heads? And you want to make it exactly as it came from the factory-I get that part,but of course,to give a little leeway on the date would up your odds of finding one,at least help the odds. Good luck either way Larry Banks |
Bigpop I'm not in any hurry and I am more than just casually aware of the way the factory's foundry and assembly line worked. But this is the head I need to replace. I'm not looking for the exact clock time for the shift too. That would be more anal. Just the date. But, thank you for your input.
Still looking for 1968 number "16" head date code E208
Thank you in advance |
Bump
Still looking for 1968 "16" head, E208.
Thanks for looking |
Want to buy E208 Head
bump
bump bump
Still looking for E208 "16" casing head.
