2" carb spacer
I have an extra 1' spacer that I was thinking of doubleing up with the one I already use. I have seen some guys use a 2' spacer. This will be on my 535, wideports, and an unported Victor. Would it be worth trying, I think it may like it.
if you already have the spacer and the hood clearance the try it. all you have to loose is 2 passes down the track.
Give it a try. Some combo's work better with a 2" spacer and some don't. Only one way to find out if your car likes it or not.;)
I run a 4 hole Super Sucker on top of a open 1" spacer and it works very well.Take off the SS and the car slows down a tenth.
