Hello friends. I need a litle advice from those that are in the know !
I have a 68 Firebird HT which needs a right front fender. Rust in a small area was not repaired right and it's been worked a few times to many. Question, are the after market fenders for this car very good? Also, how does one tell where to drill holes for correct placment of the emblems? You'd think they would come with the holes, but noy ones I've seen. I also plan on replacing the lower extensions (both sides) as well as the cowel and the part under and behind the cowel that fell off going down the road because it was so rotten. Then, I want to replace the trunk as well. Are all the trunks from the restoration houses all the same? And then, I want to know about the dash color in my 68 Bird. It it always the same color as the rest of the interior? I'm thinking of changing from black to another colore because it gets really hot inside the car. Thanks for any help you may have. And good day friends. Mike ------------------ Never Mistake Kindness For Weakness !!! |
