I am replacing all the rubber lines in the car and have decied to go ahead and freshen up the rear brakes.
But where do I get new rotors and calipers from? I have found the "cheap" stuff at autozone. 50 per caliper and 60 per rotor but was hoping to find better stuff. GM has discontinued 80 Brake anything but pads! Any help is appreciated. |
I checked with my AC-Delco suppliers, and new calipers are indeed discontinued. At our repair shop, we use Wagner "loaded" reman calipers with VERY good success. I looked up part numbers for you; LH caliper: L116346, RH caliper: L116347, rotors: BD60881.
Hope this helps, Lloyd '72 Formula 400 - soon to be a 455HO, TH400, A/C, etc.; Lucerne Blue with Medium Blue Interior Restoring a '72 GTO 455HO, TH400, A/C, etc.; Sundance Orange with Parchment buckets |
You should look at the Stainless Steel Brakes package, it is reasonably priced and works well. I have seen a 69 Camaro with them on all 4 corners, looks very nice, and stops on a dime. Other than AutoZone, or Orieleys, you don't really have that many choices.
Thanks Guys.
