FREE 69’ YE 350 short block. Arkansas.
4 Attachment(s)
I have a 69’ YE 350 short block out of a fire bird thats needs to go. Guy i got it from stated the #6 rod bearing was wiped out… i havent taken the pan back off to look, i dont know the bore…has glazed cylinder walls. has a set of # 47 heads you can probably talk me out of as well. Was also told it has a Erson cam
Again, this thing is free, come get it so i dont have to store it in a lean-to or scrap it. If anything you could save some GM iorn…i am not in a position to hang onto it. Located in central Arkansas, 20 miles north of little rock in Cabot. |
Always so far away. The timing cover alone would be worth the trip if closer. I like that block though too
