The cv1 thread is now 100 percent with some ECM input.
Which system did you go with? How has the learning curve been? Stan |
Hopefully Bill will clarify this. But I took this to mean that the launch and shift RPM for the CV1s was the same as for the KRE HPs, not that the launch and shift RPM were the same as each other. Stan |
Your probably right! I wasn’t thinking that way this morning |
EHTTFMF's!!! ..... Just saying.
Carry on |
Tom V. |
Well to throw some fuel on this fire lol, i ran 9.42@141.47 in 21 at cordova on pump gas with my 505 @ 3500 lbs! eldy heads flow 350 with only 2.5 minimum csa with no tuning!
That is interesting. That would have some velocity. Stan |
That is impressive. We have a similar combo that runs 5.0's with a shot of nitrous. |
So its less than a tenth difference between Mikes High Port 505 combo. Still say something was not right with it. |
462 with cast iron HO heads, 3680lbs, working AC, 10" tire, .517 roller cam...6.66@104mph in 1991...
With modern converter technology, and modern slick compounds, it would run low 6.50s... |
Stan |
