Remember Me?
Join us now!
Menu
FAQ
Members List
Social Groups
Calendar
Search
Today's Posts
PY Albums
FAQ
Community
Calendar
Today's Posts
Search
Community Links
Social Groups
Pictures & Albums
Members List
Search Forums
Show Threads
Show Posts
Advanced Search
Find All Thanked Posts
Go to Page...
Search Forums
Search Results
Showing results 1 to 23 of 23
Search took
0.02
seconds.
Search:
Posts Made By:
BB70
Forum:
THE LOBBY
04-24-2024, 07:02 PM
3
Donated cars from Norwood '72 strike
592
Posted By
BB70
I went to Aiken HS in Cincinnati and took auto...
I went to Aiken HS in Cincinnati and took auto mechanics in the vocational program. The auto shop had a 72 Camaro and so did the body shop. They were donated from GM.
John
Forum:
THE LOBBY
03-21-2024, 05:03 PM
47
Does your Daily Driver see Wide open Throttle
1,859
Posted By
BB70
I have a Neon SRT4 that gets a good workout. The...
I have a Neon SRT4 that gets a good workout. The more rust that falls off the quicker it goes.:D
Forum:
Interior TECH
01-26-2024, 01:16 AM
3
71 T37 blue color in interior
781
Posted By
BB70
I have a 70 GTO with a blue interior in my car...
I have a 70 GTO with a blue interior in my car and had the same question. I need carpet and a headliner so I talked to a salesman at Ames and he sent 3 carpet samples so I could pick the correct...
Forum:
Pontiac - Street
12-18-2023, 06:43 PM
84
Pump Gas 455 - Starter Rapid Clicking When Cranking...
9,961
Posted By
BB70
Man, I think I might have steered you wrong, I...
Man, I think I might have steered you wrong, I thought you had a 69, but you have a 68. I don't know if they come apart the same or not.
Forum:
Pontiac - Street
12-18-2023, 11:56 AM
84
9,961
Posted By
BB70
If you look at the connector end that goes to the...
If you look at the connector end that goes to the switch, where the opening of the terminals are, there are little squares in the center of each terminal opening. Get a little ground down pick or...
Forum:
Pontiac - Street
12-12-2023, 06:25 AM
84
9,961
Posted By
BB70
Sometimes when putting in a transmisson, you may...
Sometimes when putting in a transmisson, you may have to readjust the shifter cable or if it has it the linkage that runs up to the steering column from the trans. Do the reverse lights work when put...
Forum:
Pontiac - Street
12-11-2023, 07:29 PM
84
9,961
Posted By
BB70
Instead of a test light, get a fog light bulb and...
Instead of a test light, get a fog light bulb and use jumper wires, one to the purple wire, one to a good ground. A fog light bulb will work the circuit, nice blinding light is what you want. You can...
Forum:
Pontiac - Street
08-21-2023, 08:09 PM
8
Mechanical fuel pump gaskets ?
721
Posted By
BB70
I believe that position is #1 tdc when the plug...
I believe that position is #1 tdc when the plug fires. The 2 gaskets are for if you have a plastic insulator between the pump and timing cover.
Forum:
THE LOBBY
08-15-2023, 08:07 PM
540
What did you do with your Pontiac today?
39,870
Posted By
BB70
Had this wrapped in plastic while painting the...
Had this wrapped in plastic while painting the loose parts. Cleaned up the garage some and took the plastic off so I can get block sanding on this now.
Forum:
Heating & Cooling TECH
07-20-2023, 11:10 PM
5
A/C system oil capacity
827
Posted By
BB70
I'm assuming you're just replacing the parts for...
I'm assuming you're just replacing the parts for maitenence reasons. I've always drain the old compressor into a cup, rotate the clutch hub to try to get all the old oil out. Drain the new compressor...
Forum:
70-72 GTO Tempest & LeMans TECH
07-10-2023, 09:13 PM
11
Wire Routing Clips?
883
Posted By
BB70
Zip ties with christmas tree molded on. Probably...
Zip ties with christmas tree molded on. Probably find similar at the parts store.
Forum:
04-09-2023, 06:02 PM
127
70 GTO Build thread
23,967
Posted By
BB70
Looks very nice. You're moving along at a good...
Looks very nice. You're moving along at a good pace it seems like.
Forum:
Pontiac - Street
10-05-2022, 07:38 PM
40
Condensation on windshield
4,182
Posted By
BB70
Check into finding a radiator repair place and...
Check into finding a radiator repair place and have that one fixed.
Forum:
Members Helping Members
04-25-2022, 05:17 AM
15
Recurring fuel leaks (not a Pontiac)
1,290
Posted By
BB70
No Greg, I don't have any part numbers or...
No Greg, I don't have any part numbers or anything. I was just going by the appearance of the hose. The hose that I have used in the past has printing on it saying hi press fuel or something and has...
Forum:
04-24-2022, 05:03 PM
15
1,290
Posted By
BB70
I would follow Sirrotica's advise Greg. There is...
I would follow Sirrotica's advise Greg. There is better quality hose for that, the worm clamps are temporary in my mind. The other type hose clamp you have on there is correct but needs to be...
Forum:
Pontiac - Race
04-24-2022, 04:38 PM
1
Vibration on decelaration
500
Posted By
BB70
I would pull the driveshaft and flex the u joints...
I would pull the driveshaft and flex the u joints to see if one is hurt.
Forum:
Pontiac - Race
04-21-2022, 10:56 AM
13
Nostalgia Trans Am race
1,100
Posted By
BB70
Glad you guys liked it, the announcers were...
Glad you guys liked it, the announcers were pretty lame. It would have been cool to have Sam Posey or maybe Tommy Kendall doing it.
Forum:
Pontiac - Race
04-20-2022, 07:18 PM
13
1,100
Posted By
BB70
https://youtu.be/IYaUsZV4DEE
The race has 2 Pontiacs in it, Boss Mustangs, Camaro's- and a nice ending.😁
Forum:
Pontiac - Race
04-27-2021, 04:56 PM
11
Plug to seal factory dipstick tube location
2,650
Posted By
BB70
I used a small cup plug- freeze out plug.
Forum:
Pontiac - Race
02-28-2020, 10:05 PM
25
Oil pan choice
3,605
Posted By
BB70
I use the good black permatex engine rtv between...
I use the good black permatex engine rtv between the block and tray or scraper. Beforehand wipe both surfaces with brake clean on a paper towel. Use a small bead , go to the inside of the bolt holes...
Forum:
Pontiac - Race
02-20-2020, 08:00 PM
25
Oil pan choice
3,605
Posted By
BB70
I have a hydraulic tank fluid level indicator on...
I have a hydraulic tank fluid level indicator on my pan and at idle 1200 rpm's the level has dropped 2 qts. Sorry about the sideways picture.
Forum:
Pontiac - Street
11-06-2019, 08:08 PM
1
Tranny Starup
419
Posted By
BB70
What the ex used to say, quit playing with it and...
What the ex used to say, quit playing with it and put it in- lol.
Forum:
66-67 GTO Tempest & LeMans TECH
07-06-2014, 09:42 PM
16
Starter shim proceedure
695
Posted By
BB70
I believe you should have a gap of .030 or so at...
I believe you should have a gap of .030 or so at the bottom of every tooth that is fully engaged. You can take the solenoid off, bolt up the starter and manually engage the starter drive to...
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
How to Subscribe to the Pontiac Journal
Pontiac Journal
PY Online Parts Lookup
General Forums
THE LOBBY
Industry Stuff
GTOG8TA.COM Late Model Stuff
Ames Customer Satisfaction Forum
Garage Sale
Pontiac Business Entities Exchange
Missing Pontiacs, Parts or Trailers
Test & Tune
YOUR BEST PONTIAC STORIES
Clubs, Events & Regional Discussion
National Events
Northeast
Southeast
Midwest
BuckeyeGoats.com
Pacific
West
Southwest
Canada, Mexico and Other Countries
General Classic PONTIAC TECH
The Body Shop TECH
Pontiac - Street
Pontiac - Race
Pontiac - Boost
LS Talk
Interior TECH
Suspension TECH
Exhaust TECH
Non Pontiac Motors in Pontiacs
Tri-Power Tech
Electrical Tech
EFI Tech
Classic TECH- specs, codes, resto issues FORUMS
60 & Older Pontiac TECH
61-63 Tempest & LeMans TECH
61-66 Big Pontiac TECH
64-65 GTO Tempest & LeMans TECH
OHC-6 TECH
67-79 Big Pontiac TECH
67-69 Firebird TECH
68-69 GTO Tempest & LeMans TECH
69-71 Judges only TECH
69-77 Grand Prix TECH
70-73 Firebird & TA TECH
71-77 Ventura including 74 GTO TECH
73-77 A-body TECH
74-76 Firebird & TA TECH
77-81 Firebird & Trans Am TECH
1982-92 TA & FB TECH
78 and Newer G-body Pontiac TECH
2004-06 GTO & 2008-09 G8 Tech & Chat
Other models Pontiac Tech
General Late Model Tech
PY Welcomes 1993-02 Firebird/Trans Am Owners
93-02 General Tech/Discussion
93-02 Interior Tech
93-02 Exterior Tech
93-02 Engine Tech
93-02 Transmission Tech
93-02 Exhaust Tech
93-02 Race Tech
93-02 Electrical Tech
93-02 Suspension Tech
93-02 Wheels/Tires
1993-02 Firebird/Trans Ams FOR SALE/WANTED
1993-02 Firebird/Trans Am Parts FOR SALE/WANTED
PY Welcomes 2004-06 GTO Owners
04-06 General Tech/Discussion
04-06 Interior Tech
04-06 Exterior Tech
04-06 Engine Tech
04-06 Transmission Tech
04-06 Exhaust Tech
04-06 Race Tech
04-06 Electrical Tech
04-06 Suspension Tech
04-06 Wheels/Tires
2004-06 GTOs FOR SALE/WANTED
2004-06 GTO Parts FOR SALE/WANTED
PY Welcomes 2008-09 G8 owners
G8 General Tech/Discussion
G8 Interior Tech
G8 Exterior Tech
G8 Engine Tech
G8 Transmission Tech
G8 Exhaust Tech
G8 Race Tech
G8 Electrical Tech
G8 Suspension Tech
G8 Wheels/Tires
2008-09 G8s FOR SALE/WANTED
2008-09 G8 Parts FOR SALE/WANTED
BUY, SELL, TRADE Classic PONTIAC "PARTS"
Performance Parts For Sale/Wanted
61-77 GTO, Tempest & LeMans Parts For SALE
61-77 GTO, Tempest & LeMans Parts WANTED
Big Pontiac (incl G-body)Parts For SALE
OHC 6 Buy/Sell/Trade
Big Pontiac(incl G-body)Parts WANTED
67-81 Firebird & TA Parts FOR SALE
67-81 Firebird & TA Parts WANTED
1982-1992 TA & FB parts FOR SALE
1982-1992 TA & FB parts WANTED
LS Parts for Sell/Trade
All other Pontiac parts for sale/wanted
Collectibles FOR SALE
Collectibles WANTED
SOLD Parts
BUY, SELL, TRADE Classic PONTIACS
Big Pontiacs(including G-body) FOR SALE
Big Pontiacs (incl. G-body) WANTED
61-77 GTO LeMans & Tempests FOR SALE
61-77 GTO LeMans & Tempests WANTED
67-92 Firebirds & Trans Ams FOR SALE
67-92 Firebirds & Trans Ams WANTED
All Other Pontiacs FOR SALE
All Other Pontiacs WANTED
SOLD Pontiacs
06:36 PM
-- Responsive 2017
-- PY Online 2015
-- Late Model - Blue
-- Default Style
---- PY Forums (green)
-- Test
-- 100% Default
Contact Us
Home
