Forum: Pontiac - Street
Yesterday, 09:28 PM
I saw that video last year. It made me think I...
I saw that video last year. It made me think I ran a -.005 set with this current shortblock. it was tight hard to put on. Late last year I swapped my looser standard set on..see what happens I'm...
04-23-2024, 06:44 AM
"The 850 CFM Edelbrock carb flows more that an...
"The 850 CFM Edelbrock carb flows more that an SD-455 carb on my flow bench."
The Edelbrock 1910 is a copy of a 1980 Chevy truck carburetor part number 17080213. They set the full open angle of...
04-22-2024, 06:58 PM
Maybe this will help explain things
https://forums.maxperformanceinc.com/forums/showthread.php?t=826882&referrerid=134156
Pontiac found the 850 Holley to make more power than the Q-jet on...
04-22-2024, 03:44 PM
Forum: Exhaust TECH
03-23-2024, 02:40 PM
Forum: Heating & Cooling TECH
12-03-2023, 02:15 AM
09-06-2023, 11:25 AM
08-07-2023, 04:00 PM
Lets say that cam was ground on a 108, you...
Lets say that cam was ground on a 108, you installed it dot to dot. per instructions. But never degree it, now for some reason (gear set ) being off, you check it ( degree it in ). And it comes in at...
08-04-2023, 10:45 AM
Overheating solved 67 Firebird 400
My 67 Firebird 400/TH400 factory 3 core radiator would not cool! It would run 190-220 deg. and sometimes hotter regardless of what I did. I installed a Cold-Case #CHC11A aluminum radiator, and all...
06-03-2022, 07:20 PM
Fast ramps stink, suck, and wear badly. Fast...
Fast ramps stink, suck, and wear badly. Fast ramps are any thing less than 50* between ADV-.050" check Duration.
Slow ramps allow higher RPM, better filling, and increased reliability. Vacuum...
11-17-2021, 01:10 PM
Forum: Interior TECH
09-10-2021, 02:23 PM
09-10-2021, 01:59 PM
09-10-2021, 01:24 PM
09-10-2021, 01:10 PM
Right, but the seat cover will still need to be...
Right, but the seat cover will still need to be hog-ringed to the same location despite the increase in bolster height. If you increase the bolster height, there is the risk that the seat covers will...
09-10-2021, 06:16 AM
09-09-2021, 07:53 PM
09-09-2021, 12:55 PM
08-08-2021, 02:39 PM
07-07-2021, 11:03 PM
05-17-2021, 03:52 PM
02-23-2021, 05:16 PM
🔰 Hiya 70GS455...
I think it’s Silver Sport not Silver State...I really appreciate your pointing out the alternative offset shifter...👍
https://shiftsst.com/...
