Remember Me?
Join us now!
Menu
FAQ
Members List
Social Groups
Calendar
Search
Today's Posts
PY Albums
FAQ
Community
Calendar
Today's Posts
Search
Community Links
Social Groups
Pictures & Albums
Members List
Search Forums
Show Threads
Show Posts
Advanced Search
Find All Thanked Posts
Go to Page...
Search Forums
Search Results
Page 1 of 5
1
2
3
Last
Showing results 1 to 25 of 125
Search took
0.03
seconds.
Search:
Posts Made By:
GoreMaker
Forum:
77-81 Firebird & Trans Am TECH
08-22-2023, 05:16 PM
2
Remote Oil Filter Location
415
Posted By
Gator67
Here's where I installed the remote oil filter on...
Here's where I installed the remote oil filter on my '70. I wanted to install it on the subframe in the same general area to have better access for oil changes, but I run an aftermarket subframe and...
Forum:
08-20-2023, 05:35 PM
2
415
Posted By
nas t eh
I don’t have AC, but I don’t think it would...
I don’t have AC, but I don’t think it would matter much I’d just run the hoses under the AC stuff, my dual remote housing is on the passenger side of the rad support.
Forum:
Electrical Tech
07-24-2023, 08:14 AM
4
Alarm Door Trigger Wiring
561
Posted By
Bill Hanlon
No, it is +12v when the door is closed and ground...
No, it is +12v when the door is closed and ground when it is open.
Forum:
Pontiac - Street
05-02-2023, 06:11 AM
4
Pushrod Guideplates
635
Posted By
steve25
You do not need to buy a thing, use your Pontiac...
You do not need to buy a thing, use your Pontiac ones!
If the need further tweaking then just cut them into 4 separate ones .
The good thing about these also is should you ever need to step up...
Forum:
Pontiac - Street
05-01-2023, 10:50 PM
4
Pushrod Guideplates
635
Posted By
b-man
ISKY and Comp both make adjustable guide plates,...
ISKY and Comp both make adjustable guide plates, they’re actually for SBC engines but they work for Pontiacs using 5/16” pushrods.
Factory Pontiac guide plates are more than good enough, if...
Forum:
Suspension TECH
04-16-2023, 09:40 AM
7
Rear End U-Bolt Tightening
689
Posted By
78w72
i tightened mine to the factory spec, ~45-50lb...
i tightened mine to the factory spec, ~45-50lb using new rubber pads or poly pads. the plate distance to the rear end on yours could have been retightened over the years or serviced by a guy with an...
Forum:
Pontiac - Street
02-03-2023, 05:18 AM
10
Confused by this ported vacuum switch
1,770
Posted By
Kenth
If the TVS is connected according to the manual,...
If the TVS is connected according to the manual, it operates only when idling. While driving, the ported source on carb acts just like, well, a ported source.
SMP PVS24 opens @ 125°F and SMP PVS51...
Forum:
Exhaust TECH
01-31-2023, 12:14 PM
21
Ram Air Manifolds Hardware
3,548
Posted By
ZeGermanHam
This is what drove me absolutely nuts. It's crazy...
This is what drove me absolutely nuts. It's crazy making to be told that time after time and have it never be true.
Forum:
Exhaust TECH
01-27-2023, 11:52 PM
21
3,548
Posted By
b-man
Measure the ideal bolt lengths for each location...
Measure the ideal bolt lengths for each location and go shopping. If you can’t find the exact length bolt you need for some then buy longer ones and cut them down, carefully chamfering and deburring...
Forum:
Pontiac - Street
01-25-2023, 12:03 PM
13
Most Stock-Looking Reproduction Chrome Valve Covers
1,214
Posted By
Baron Von Zeppelin
Most Stock-Looking Reproduction Chrome Valve...
Try posting this same thread in the 77-81 TA section also .
Not many others are going to know what you are actually looking for.
Most of us...
Forum:
Pontiac - Street
01-25-2023, 09:25 AM
13
1,214
Posted By
rwfisher
For the look your after you may want to look at...
For the look your after you may want to look at shops that do Hydrochroming paint process…
Forum:
Pontiac - Street
01-25-2023, 05:34 AM
13
1,214
Posted By
LStathas
Most platers use a "lot" charge. You may ask them...
Most platers use a "lot" charge. You may ask them how many you can do in a lot and get other members to go in on a group buy.
I would also shop other places in other states. Some states really...
Forum:
Pontiac - Street
01-25-2023, 02:04 AM
13
1,214
Posted By
Baron Von Zeppelin
Have you tried 000 or 00 steel wool on the old...
Have you tried 000 or 00 steel wool on the old ones ?
Brillo pads and SoS pads are about 00 grade.
The mid to late 70's type , are called "flash-chrome"
Most of the catalog repops will be...
Forum:
Pontiac - Street
01-25-2023, 01:32 AM
13
1,214
Posted By
Jack Gifford
That nickel plating quote is crazy. Nickel...
That nickel plating quote is crazy. Nickel plating is usually inexpensive. Just a few months ago I had the lakester's DOHC sprockets nickel plated for under $100.
Forum:
Pontiac - Street
01-24-2023, 11:20 PM
13
1,214
Posted By
tom s
The ones I have bought from In-line tube have...
The ones I have bought from In-line tube have been great.Tom
Forum:
Pontiac - Street
11-21-2022, 05:45 PM
17
Clearance issue between cam bolt and timing cover
1,222
Posted By
25stevem
I am glad you had to take it apart, because there...
I am glad you had to take it apart, because there does not look to be drop 1 of oil, on the timing chain, nor in the rollers which is even worse!
Am I correct in the way I am seeing that?
If...
Forum:
Pontiac - Street
11-21-2022, 03:30 PM
17
1,222
Posted By
Verdoro 68
The stock cam bolt and washer sit below the fuel...
The stock cam bolt and washer sit below the fuel pump eccentric, so it looks like the bolt/washer combo you are using is too tall and rubbing against the timing cover.
I have a Simms torrington...
Forum:
Pontiac - Street
11-19-2022, 05:27 AM
62
Mutilated Stock Intake Manifold
5,901
Posted By
Cliff R
"How much extra horsepower & torque is there to...
"How much extra horsepower & torque is there to be gained by porting the iron intake and at what power level?"
I spent several years porting/modifying my factory iron intake taking every chance it...
Forum:
11-16-2022, 12:11 PM
1
Which Power Steering Pump Reservoir?
670
Posted By
nUcLeArEnVoY
Any short-neck Saginaw pump and reservoir should...
Any short-neck Saginaw pump and reservoir should work, but make sure that it's clocked correctly for the car. My '79 T/A with a 400 had a PS pump and reservoir on it when I first got it that was...
Forum:
Pontiac - Street
11-13-2022, 11:13 AM
21
This Color Is So Wrong...
2,238
Posted By
TxSportCoupe
https://uploads.tapatalk-cdn.com/20221113/8394b1e3...
https://uploads.tapatalk-cdn.com/20221113/8394b1e361695fd4fc70b406f71685b1.jpg
Been thoroughly through the wringer on this one. OER makes the only paint that doesn’t make me want to paint it all...
Forum:
Pontiac - Street
11-13-2022, 08:37 AM
21
2,238
Posted By
Half-Inch Stud
Awe geez, don’t make the fella cry. Try that...
Try that lighter blue on top of that dark blue, should adhere and tack-in real nice.
Forum:
Pontiac - Street
11-11-2022, 12:55 PM
62
5,901
Posted By
Cliff R
Just a note on dual plane intakes and dividers. ...
Just a note on dual plane intakes and dividers. It is best to leave the divider intact and full height. At most you can remove a small portion of it between the secondaries, but that is more easily...
Forum:
11-06-2022, 11:33 PM
72
I Miss Recaro Seats!
12,566
Posted By
Maxthe222
King seats for any Firebird, I am putting a set...
King seats for any Firebird, I am putting a set of VSE spec Recaro 1981 IdealSitzN's back into my Fire Am and having them trimmed in the factory Carmine Red Hobnail material, just like how GM did...
Forum:
11-06-2022, 12:23 AM
72
12,566
Posted By
MalteseFalcon
I just picked up a set of '81 Pace Car Recaros to...
I just picked up a set of '81 Pace Car Recaros to use in my Fire Am project as an alternative to the Corbeau GT-8s. Since I've picked them up, I've learned two things that you may find interesting: ...
Forum:
Heating & Cooling TECH
11-05-2022, 10:40 AM
1
77 Trans Am Coolant and Heater Core Plumbing
1,095
Posted By
78w72
there is no vac actuated cutoff valve on these...
there is no vac actuated cutoff valve on these cars of this era. im not sure where or how they restricted coolant flow but probably in the head outlet like you mentioned.
on my E-head motor i...
Page 1 of 5
1
2
3
Last
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
How to Subscribe to the Pontiac Journal
Pontiac Journal
PY Online Parts Lookup
General Forums
THE LOBBY
Industry Stuff
GTOG8TA.COM Late Model Stuff
Ames Customer Satisfaction Forum
Members Helping Members
Garage Sale
Pontiac Business Entities Exchange
Missing Pontiacs, Parts or Trailers
Test & Tune
YOUR BEST PONTIAC STORIES
Clubs, Events & Regional Discussion
National Events
Northeast
Southeast
Midwest
BuckeyeGoats.com
Pacific
West
Southwest
Canada, Mexico and Other Countries
General Classic PONTIAC TECH
The Body Shop TECH
Pontiac - Street
Pontiac - Race
Pontiac - Boost
LS Talk
Interior TECH
Suspension TECH
Exhaust TECH
Non Pontiac Motors in Pontiacs
Tri-Power Tech
Electrical Tech
EFI Tech
Classic TECH- specs, codes, resto issues FORUMS
60 & Older Pontiac TECH
61-63 Tempest & LeMans TECH
61-66 Big Pontiac TECH
64-65 GTO Tempest & LeMans TECH
OHC-6 TECH
66-67 GTO Tempest & LeMans TECH
67-79 Big Pontiac TECH
67-69 Firebird TECH
68-69 GTO Tempest & LeMans TECH
69-71 Judges only TECH
69-77 Grand Prix TECH
70-72 GTO Tempest & LeMans TECH
70-73 Firebird & TA TECH
71-77 Ventura including 74 GTO TECH
73-77 A-body TECH
74-76 Firebird & TA TECH
1982-92 TA & FB TECH
78 and Newer G-body Pontiac TECH
2004-06 GTO & 2008-09 G8 Tech & Chat
Other models Pontiac Tech
General Late Model Tech
PY Welcomes 1993-02 Firebird/Trans Am Owners
93-02 General Tech/Discussion
93-02 Interior Tech
93-02 Exterior Tech
93-02 Engine Tech
93-02 Transmission Tech
93-02 Exhaust Tech
93-02 Race Tech
93-02 Electrical Tech
93-02 Suspension Tech
93-02 Wheels/Tires
1993-02 Firebird/Trans Ams FOR SALE/WANTED
1993-02 Firebird/Trans Am Parts FOR SALE/WANTED
PY Welcomes 2004-06 GTO Owners
04-06 General Tech/Discussion
04-06 Interior Tech
04-06 Exterior Tech
04-06 Engine Tech
04-06 Transmission Tech
04-06 Exhaust Tech
04-06 Race Tech
04-06 Electrical Tech
04-06 Suspension Tech
04-06 Wheels/Tires
2004-06 GTOs FOR SALE/WANTED
2004-06 GTO Parts FOR SALE/WANTED
PY Welcomes 2008-09 G8 owners
G8 General Tech/Discussion
G8 Interior Tech
G8 Exterior Tech
G8 Engine Tech
G8 Transmission Tech
G8 Exhaust Tech
G8 Race Tech
G8 Electrical Tech
G8 Suspension Tech
G8 Wheels/Tires
2008-09 G8s FOR SALE/WANTED
2008-09 G8 Parts FOR SALE/WANTED
BUY, SELL, TRADE Classic PONTIAC "PARTS"
Performance Parts For Sale/Wanted
61-77 GTO, Tempest & LeMans Parts For SALE
61-77 GTO, Tempest & LeMans Parts WANTED
Big Pontiac (incl G-body)Parts For SALE
OHC 6 Buy/Sell/Trade
Big Pontiac(incl G-body)Parts WANTED
67-81 Firebird & TA Parts FOR SALE
67-81 Firebird & TA Parts WANTED
1982-1992 TA & FB parts FOR SALE
1982-1992 TA & FB parts WANTED
LS Parts for Sell/Trade
All other Pontiac parts for sale/wanted
Collectibles FOR SALE
Collectibles WANTED
SOLD Parts
BUY, SELL, TRADE Classic PONTIACS
Big Pontiacs(including G-body) FOR SALE
Big Pontiacs (incl. G-body) WANTED
61-77 GTO LeMans & Tempests FOR SALE
61-77 GTO LeMans & Tempests WANTED
67-92 Firebirds & Trans Ams FOR SALE
67-92 Firebirds & Trans Ams WANTED
All Other Pontiacs FOR SALE
All Other Pontiacs WANTED
SOLD Pontiacs
01:16 PM
-- Responsive 2017
-- PY Online 2015
-- Late Model - Blue
-- Default Style
---- PY Forums (green)
-- Test
-- 100% Default
Contact Us
Home
