Remember Me?
Join us now!
Menu
FAQ
Members List
Social Groups
Calendar
Search
Today's Posts
PY Albums
FAQ
Community
Calendar
Today's Posts
Search
Community Links
Social Groups
Pictures & Albums
Members List
Search Forums
Show Threads
Show Posts
Advanced Search
Find All Thanked Posts
Go to Page...
Search Forums
Search Results
Page 1 of 20
1
2
3
11
Last
Showing results 1 to 25 of 500
Search took
0.22
seconds.
Search:
Posts Made By:
Cliff R
Forum:
Pontiac - Street
Yesterday, 01:52 PM
6
Hunting Super Duty camshaft
263
Posted By
Cliff R
It's just a lot easier to forget about using the...
It's just a lot easier to forget about using the original distributor gear and also no need whatsoever to run an 80psi oil pump in one.
I've built a good many 455 HO and Super Duty engines. They...
Forum:
Pontiac - Street
06-03-2024, 08:33 AM
22
New motor tuning mystery
736
Posted By
Cliff R
"Not an option as in it is a must do?" Yes,...
Yes, HEI's are designed to stop the mechanical advance when the "flats" on the weights reach the "flats" on the center cam. The factory springs are strong...
Forum:
Pontiac - Street
06-02-2024, 02:47 PM
22
736
Posted By
Cliff R
You cannot do this with an HEI, unless it’s been...
You cannot do this with an HEI, unless it’s been modified for a positive stop,
+2
I'll also add that welding or making a positive stop for an HEI is NOT an option. They are designed to stop...
Forum:
Pontiac - Street
05-23-2024, 06:01 AM
11
‘69 with 10.5:1 CR advertised. what was the actual CR?
518
Posted By
Cliff R
Comp grinds everything in their arsenal on a...
Comp grinds everything in their arsenal on a tight LSA. That NEVER works out well until you start getting into some of their grinds with a lot of seat timing and even then there are a LOT better...
Forum:
Pontiac - Street
05-22-2024, 04:22 AM
34
Best compression for Crower 60919 cam help
1,851
Posted By
Cliff R
At least 10 to 1, wouldn't hurt my feelings if it...
At least 10 to 1, wouldn't hurt my feelings if it came out a little higher.
My own 455 with 6X-4 heads was right at 9.97 to 1 and EASILY managed pump gas, even 89 octane and never grumbled much....
Forum:
Pontiac - Street
05-19-2024, 08:12 AM
15
Help Decipher CC HR Cam
840
Posted By
Cliff R
I used SD's Old Faithful cam 236/245/112 in my...
I used SD's Old Faithful cam 236/245/112 in my last 455 at 11.3 to 1 compression. It was pretty "tame" at idle making 13.5" vacuum at 750rpm's with only 10 degrees initial timing. Fine on pump gas...
Forum:
Pontiac - Street
05-19-2024, 08:01 AM
34
1,851
Posted By
Cliff R
The "old" version of the 60919 cam is a SPC-8...
The "old" version of the 60919 cam is a SPC-8 from CMC. Crower simply "juggled" the numbers to make it look like their own cam.
Tey were NOT on a 112LSA, nor were they shorter seat timing.
Forum:
Pontiac - Street
05-17-2024, 07:57 AM
82
Engine Oil Additives
3,001
Posted By
Cliff R
Snake oil or not I use Lucas oil additive and...
Snake oil or not I use Lucas oil additive and their fuel treatment and will continue to do so. I don't know jack crap about how well the oil additive works, but for sure the fuel additive improves...
Forum:
Pontiac - Street
05-15-2024, 10:03 PM
18
Vacuum issue, timing issue or tuner issue
872
Posted By
Cliff R
I have limiters for stock points vacuum advance...
I have limiters for stock points vacuum advance units that are basically just "drop-in". I can also modify the factory VA units to add exactly how much I want them to.
I would NOT recommened an...
Forum:
Pontiac - Street
05-14-2024, 07:40 AM
82
3,001
Posted By
Cliff R
I run both Lucas oil additive and Lucas fuel...
I run both Lucas oil additive and Lucas fuel treatment in everything here and have for decades.
Couldn't tell if the oil treatment helps but I've had zero issues with any engines I use it in. ...
Forum:
THE LOBBY
05-13-2024, 01:22 PM
21
New Ebay Buyer Rip off Method
1,224
Posted By
Cliff R
Ebay needs to establish a sellers protection plan...
Ebay needs to establish a sellers protection plan from the sounds of it.
A good friend of mine worked at Lowe's for years till retiring recently. He told me that every time a big storm came thru...
Forum:
THE LOBBY
05-13-2024, 08:22 AM
21
1,224
Posted By
Cliff R
New scam on Ebay, at least to me. Been selling a few parts and shop tools, etc since I retired and have been cleaning up the back room. I posted an older OTC Fuel Injector Cleaning Kit on Ebay, sold...
Forum:
THE LOBBY
05-10-2024, 06:42 AM
25
Air compressor *Not* required?
880
Posted By
Cliff R
In recent years I've outfitted my arsenal of...
In recent years I've outfitted my arsenal of tools with battery powered stuff. Almost all of it is Dewalt, 18 and 20V. The 18 volt batteries aren't that great so I have adapters for the 20V.
My...
Forum:
Pontiac - Street
05-08-2024, 07:29 PM
26
400 Rebuild and conversion to EFI
912
Posted By
Cliff R
"Thanks Cliff. Do you think that the 8 or 9:1...
"Thanks Cliff. Do you think that the 8 or 9:1 complaint ratio of Holley over FAST and FiTech is the due to a similar ratio of what is being run, in other words, do you think that there are 8 or 9...
Forum:
Pontiac - Street
05-08-2024, 12:36 PM
17
SD Performance Old Faithful
951
Posted By
Cliff R
The 2.0 version is for sure a bigger profile, and...
The 2.0 version is for sure a bigger profile, and more aggressive.
This will require room for that much lift and pressures to keep thing under control at high RPM's.
For "mild" set-ups and HR...
Forum:
Pontiac - Street
05-08-2024, 12:20 PM
26
912
Posted By
Cliff R
Good points made on manual trans set-ups. ...
When I tuned HD twin cam engines, for example, I would install wide ban 02's and start with a "canned" map very close for the application. The companies...
Forum:
Pontiac - Street
05-08-2024, 08:11 AM
26
912
Posted By
Cliff R
Couple of observations. I get hundreds of...
I get hundreds of emails and calls to the shop from folks who are NOT happy with their "electric carburetor" conversions and want to go back to a carburetor. The Holley...
Forum:
Pontiac - Street
05-07-2024, 06:59 AM
10
Changing Roller Rocker Arms: Setting Pre-Load on Pumped Up Hydraulic Roller Lifters
616
Posted By
Cliff R
In a perfect World it does NOT matter how much...
In a perfect World it does NOT matter how much pre-load you give a hydraulic lifter as long as it falls somewhere in the range of the plunger travel.
So in theory you could set them to zero...
Forum:
Pontiac - Street
05-07-2024, 06:39 AM
15
Any tips on places to buy general use torque convertors ?
575
Posted By
Cliff R
Transtar Industries gobbled up most of the market...
Transtar Industries gobbled up most of the market in recent years. I used them way back when I still did transmission builds in the shop and never had any issues with their stock replacement...
Forum:
THE LOBBY
04-30-2024, 06:12 AM
32
Has anybody heard of this guy?
2,404
Posted By
Cliff R
Pretty much a first class douche IMHO. I never...
Pretty much a first class douche IMHO. I never heard of him till a few months ago when he called here looking for jets .080" and larger main jets for a Quadrajet carburetor. Coincidentally it was...
Forum:
Pontiac - Street
04-24-2024, 07:27 AM
11
Got my grandson 4l60e broken down
617
Posted By
Cliff R
The 4L60E is a better unit than the early...
The 4L60E is a better unit than the early 700-4R/4L60's. The first big change to that transmission came in 1987 when the factory did about a dozen needed upgrades to the original design. The 4L60E's...
Forum:
Pontiac - Street
04-23-2024, 06:44 AM
55
1000+ cfm from a Qjet
4,215
Posted By
Cliff R
"The 850 CFM Edelbrock carb flows more that an...
"The 850 CFM Edelbrock carb flows more that an SD-455 carb on my flow bench."
The Edelbrock 1910 is a copy of a 1980 Chevy truck carburetor part number 17080213. They set the full open angle of...
Forum:
Pontiac - Street
04-22-2024, 03:44 PM
55
4,215
Posted By
Cliff R
It works just like I said it did. All the Q-jets...
It works just like I said it did. All the Q-jets with the larger primaries are NOT "800" cfm, and never have been. The factory used quite a few different stops on the secondary shaft to control CFM...
Forum:
Pontiac - Street
04-22-2024, 02:29 PM
55
4,215
Posted By
Cliff R
A late model Q-jet or any that have the larger...
A late model Q-jet or any that have the larger primaries are 850 cfm not 800, if you set the angle of the secondary air flaps as described in my book. I typically don't waste my time trying to...
Forum:
Pontiac - Street
04-21-2024, 06:52 AM
55
4,215
Posted By
Cliff R
The article in question here suggests 4-6psi but...
The article in question here suggests 4-6psi but doesn't mention what carb is being used or the size of the fuel inlet seat. I suspect that the author was either using a 1968 or older carb for the...
Page 1 of 20
1
2
3
11
Last
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
How to Subscribe to the Pontiac Journal
Pontiac Journal
PY Online Parts Lookup
General Forums
THE LOBBY
Industry Stuff
GTOG8TA.COM Late Model Stuff
Ames Customer Satisfaction Forum
Members Helping Members
Garage Sale
Pontiac Business Entities Exchange
Missing Pontiacs, Parts or Trailers
Test & Tune
YOUR BEST PONTIAC STORIES
Clubs, Events & Regional Discussion
National Events
Northeast
Southeast
Midwest
BuckeyeGoats.com
Pacific
West
Southwest
Canada, Mexico and Other Countries
General Classic PONTIAC TECH
The Body Shop TECH
Pontiac - Street
Pontiac - Race
Pontiac - Boost
LS Talk
Interior TECH
Heating & Cooling TECH
Suspension TECH
Exhaust TECH
Non Pontiac Motors in Pontiacs
Tri-Power Tech
Electrical Tech
EFI Tech
Classic TECH- specs, codes, resto issues FORUMS
60 & Older Pontiac TECH
61-63 Tempest & LeMans TECH
61-66 Big Pontiac TECH
64-65 GTO Tempest & LeMans TECH
OHC-6 TECH
66-67 GTO Tempest & LeMans TECH
67-79 Big Pontiac TECH
67-69 Firebird TECH
68-69 GTO Tempest & LeMans TECH
69-71 Judges only TECH
69-77 Grand Prix TECH
70-72 GTO Tempest & LeMans TECH
70-73 Firebird & TA TECH
71-77 Ventura including 74 GTO TECH
73-77 A-body TECH
74-76 Firebird & TA TECH
77-81 Firebird & Trans Am TECH
1982-92 TA & FB TECH
78 and Newer G-body Pontiac TECH
2004-06 GTO & 2008-09 G8 Tech & Chat
Other models Pontiac Tech
General Late Model Tech
PY Welcomes 1993-02 Firebird/Trans Am Owners
93-02 General Tech/Discussion
93-02 Interior Tech
93-02 Exterior Tech
93-02 Engine Tech
93-02 Transmission Tech
93-02 Exhaust Tech
93-02 Race Tech
93-02 Electrical Tech
93-02 Suspension Tech
93-02 Wheels/Tires
1993-02 Firebird/Trans Ams FOR SALE/WANTED
1993-02 Firebird/Trans Am Parts FOR SALE/WANTED
PY Welcomes 2004-06 GTO Owners
04-06 General Tech/Discussion
04-06 Interior Tech
04-06 Exterior Tech
04-06 Engine Tech
04-06 Transmission Tech
04-06 Exhaust Tech
04-06 Race Tech
04-06 Electrical Tech
04-06 Suspension Tech
04-06 Wheels/Tires
2004-06 GTOs FOR SALE/WANTED
2004-06 GTO Parts FOR SALE/WANTED
PY Welcomes 2008-09 G8 owners
G8 General Tech/Discussion
G8 Interior Tech
G8 Exterior Tech
G8 Engine Tech
G8 Transmission Tech
G8 Exhaust Tech
G8 Race Tech
G8 Electrical Tech
G8 Suspension Tech
G8 Wheels/Tires
2008-09 G8s FOR SALE/WANTED
2008-09 G8 Parts FOR SALE/WANTED
BUY, SELL, TRADE Classic PONTIAC "PARTS"
Performance Parts For Sale/Wanted
61-77 GTO, Tempest & LeMans Parts For SALE
61-77 GTO, Tempest & LeMans Parts WANTED
Big Pontiac (incl G-body)Parts For SALE
OHC 6 Buy/Sell/Trade
Big Pontiac(incl G-body)Parts WANTED
67-81 Firebird & TA Parts FOR SALE
67-81 Firebird & TA Parts WANTED
1982-1992 TA & FB parts FOR SALE
1982-1992 TA & FB parts WANTED
LS Parts for Sell/Trade
All other Pontiac parts for sale/wanted
Collectibles FOR SALE
Collectibles WANTED
SOLD Parts
BUY, SELL, TRADE Classic PONTIACS
Big Pontiacs(including G-body) FOR SALE
Big Pontiacs (incl. G-body) WANTED
61-77 GTO LeMans & Tempests FOR SALE
61-77 GTO LeMans & Tempests WANTED
67-92 Firebirds & Trans Ams FOR SALE
67-92 Firebirds & Trans Ams WANTED
All Other Pontiacs FOR SALE
All Other Pontiacs WANTED
SOLD Pontiacs
07:53 AM
-- Responsive 2017
-- PY Online 2015
-- Late Model - Blue
-- Default Style
---- PY Forums (green)
-- Test
-- 100% Default
Contact Us
Home
