Remember Me?
Join us now!
Menu
FAQ
Members List
Social Groups
Calendar
Search
Today's Posts
PY Albums
FAQ
Community
Calendar
Today's Posts
Search
Community Links
Social Groups
Pictures & Albums
Members List
Search Forums
Show Threads
Show Posts
Advanced Search
Find All Thanked Posts
Go to Page...
Search Forums
Search Results
Page 1 of 8
1
2
3
Last
Showing results 1 to 25 of 185
Search took
0.04
seconds.
Search:
Posts Made By:
Formulas
Forum:
Pontiac - Street
05-23-2024, 01:58 PM
163
Different cam? Chain? Car should be faster
9,996
Posted By
Formulas
I knew there was something wrong outside the list...
I knew there was something wrong outside the list of parts
a 455 with a little bit of a cam in it good compression and 3.73 gears should bring a smile at some point..
Forum:
Pontiac - Street
05-17-2024, 02:20 PM
36
10 year old new oil????
1,219
Posted By
Formulas
Oil isn't born with additives thats why they are...
Oil isn't born with additives thats why they are added,
Be interesting to know the circumstances in which these additives are added IE the environment in which this magic takes place. Is this...
Forum:
Pontiac - Street
05-13-2024, 12:27 PM
82
Engine Oil Additives
2,759
Posted By
Formulas
The invisible boogie man, Can't be proven or...
The invisible boogie man, Can't be proven or disproven.
Forum:
Pontiac - Street
05-10-2024, 05:20 PM
32
Recipe for a reliable 400 driver
1,640
Posted By
Formulas
For building a good cruiser engine you want low...
For building a good cruiser engine you want low end torque.
Compression builds torque at every rotation of the crank if it was my goal to build a cruiser 400 i would use 85ish CC 1970 and prior...
Forum:
70-73 Firebird & TA TECH
05-09-2024, 04:02 PM
7
1970 TA Van Nuys car.
370
Posted By
Formulas
I don't believe there is charcoal in the rear...
I don't believe there is charcoal in the rear canister i believe its a over engineered attempt at vapor liquid seperation so only vapors make it to the typical round canister under the hood
Is...
Forum:
Pontiac - Street
04-22-2024, 10:12 PM
59
e head questions alot of questions
2,685
Posted By
Formulas
Do you have the standard coolant fitting that...
Do you have the standard coolant fitting that comes with Eheads?
you can drill and tap the fitting portion that screws into the head install a plug then drill the plug with a 1/4 drill bit or...
Forum:
Pontiac - Street
04-13-2024, 09:02 PM
2
Header tube temps?
372
Posted By
Formulas
#2 has the least amount obstacles in front of it...
#2 has the least amount obstacles in front of it obstructing airflow from radiator area, no alternator or power steering pump, and usually no a/c
Forum:
Pontiac - Street
03-30-2024, 07:43 PM
13
What tool?
781
Posted By
Formulas
Beading is the process
Forum:
Pontiac - Race
03-29-2024, 08:20 AM
11
Piston wall clearance and Coating skirt
671
Posted By
Formulas
Under extreme pressures and rubbing like the side...
Under extreme pressures and rubbing like the side of a piston molly coatings eventually will wear away
one may ask why bother then?
the molly coating reduces galling and wear of the piston...
Forum:
Pontiac - Street
03-28-2024, 08:58 AM
10
Pinion depth tool
690
Posted By
Formulas
Something you can do to make the process a bit...
Something you can do to make the process a bit easier is to take your old pinion bearing use a sanding drum on the inside of the race where it goes on the pinion use the slip fit bearing to get a...
Forum:
Pontiac - Race
03-24-2024, 09:46 PM
11
dowel bearings for pontiac rj
776
Posted By
Formulas
I have a stock rod cap that a machinest drilled...
I have a stock rod cap that a machinest drilled and installed a drill bushing in it for me for my BME rods i can loan it to you, might want to verify same size hole first i can check tomorrow
Forum:
Performance Parts For Sale/Wanted
03-13-2024, 08:12 PM
5
WTB: 9.400 5/16 pushrods
341
Posted By
Formulas
if you could use 9.45 i have these sitting around...
if you could use 9.45 i have these sitting around doing nothing, bought them used changed my rocker arms didn't need these, 5 are slightly different from the others, see photos
Forum:
Pontiac - Street
02-29-2024, 12:42 PM
26
Head bolts loosening
1,716
Posted By
Formulas
A possible culprit can be to much oil laying in a...
A possible culprit can be to much oil laying in a blind bolt hole
bolt goes down hydro locks on the oil then in time enough oil passes by the threads un does percieved torque
reason i would put a...
Forum:
Pontiac - Street
02-26-2024, 07:32 PM
23
Cam Degree wheel needed
1,064
Posted By
Formulas
I have the Summit wheel of fortune, No complaints...
I have the Summit wheel of fortune, No complaints here.
Forum:
Pontiac - Race
02-19-2024, 12:29 PM
19
Oil control rings
1,264
Posted By
Formulas
To put things in simple terms oil controls...
oil controls rings do what? control oil.!
Rings 1 and 2 control pressure
oil is a static creature it just gets knocked / pushed around
pressure is...
Forum:
Pontiac - Street
02-18-2024, 01:58 PM
21
calibrated resistance wire to coil
1,298
Posted By
Formulas
Any ignition system is doomed if not fed right
Forum:
Pontiac - Street
02-18-2024, 12:23 PM
21
1,298
Posted By
Formulas
Isnt pertronix supposed to use full voltage,? IE...
Isnt pertronix supposed to use full voltage,? IE your black n pink wire not giving best results?
i never ran pertronix just what i may have gathered
Forum:
Pontiac - Street
02-18-2024, 11:51 AM
81
Breaking in your new engine and Break In Oil
5,461
Posted By
Formulas
cam lobes have a grade that match the contour of...
cam lobes have a grade that match the contour of the lifters somewhat like 2 beveled gears meshing so one turns the other
spraying on a very thin layer of dry film does not change any angles
as...
Forum:
Pontiac - Street
02-12-2024, 03:39 PM
81
5,461
Posted By
Formulas
Back in the day 50 years ago synthetics were not...
Back in the day 50 years ago synthetics were not so mainstream hardly on radar and regular oils had higher levels of flat tappet goodness, different world today
I have run new engines of my own...
Forum:
Pontiac - Street
02-11-2024, 09:27 PM
8
Cam Retainer plate and timing set
510
Posted By
Formulas
Just the plate for many years . Make sure you...
Just the plate for many years . Make sure you have a bit of camshaft end play when done and Since you sound new to Pontiac take care on the fuel pump eccentric to get that right its not hard to do...
Forum:
Pontiac - Street
02-11-2024, 06:41 PM
81
5,461
Posted By
Formulas
I always have a hard time understanding how break...
I always have a hard time understanding how break in oil that increases friction for ring seat but doesn't increase friction for a lobe and lifter causing failure there, guess theres more pressure...
Forum:
Pontiac - Street
02-08-2024, 07:35 PM
44
Next step up from the 068 cam?
2,794
Posted By
Formulas
Youin's need to think outside the box, This...
Youin's need to think outside the box, This bolts down on flat / perpendicular to studs guide plate useing the bolt hole for the guide plate...
Its a aircraft structural controlled tooling drill...
Forum:
Pontiac - Street
02-08-2024, 04:19 PM
52
Interesting video on current lifter quality
2,580
Posted By
Formulas
pics of 1970 OEM 400 / 067 cam lifter
Forum:
Pontiac - Street
02-08-2024, 11:45 AM
44
2,794
Posted By
Formulas
The thing about 3/8 pressed in studs is when you...
The thing about 3/8 pressed in studs is when you stray away from original rocker lock nuts, they keep the rocking stress off of the thin sections of the stud
Forum:
Pontiac - Street
02-07-2024, 09:11 PM
52
2,580
Posted By
Formulas
I have an original 067 cam and lifters from my...
I have an original 067 cam and lifters from my 1970 400 if your interested i can dig them out for pics
Page 1 of 8
1
2
3
Last
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
How to Subscribe to the Pontiac Journal
Pontiac Journal
PY Online Parts Lookup
General Forums
THE LOBBY
Industry Stuff
GTOG8TA.COM Late Model Stuff
Ames Customer Satisfaction Forum
Members Helping Members
Garage Sale
Pontiac Business Entities Exchange
Missing Pontiacs, Parts or Trailers
Test & Tune
YOUR BEST PONTIAC STORIES
Clubs, Events & Regional Discussion
National Events
Northeast
Southeast
Midwest
BuckeyeGoats.com
Pacific
West
Southwest
Canada, Mexico and Other Countries
General Classic PONTIAC TECH
The Body Shop TECH
Pontiac - Street
Pontiac - Race
Pontiac - Boost
LS Talk
Interior TECH
Heating & Cooling TECH
Suspension TECH
Exhaust TECH
Non Pontiac Motors in Pontiacs
Tri-Power Tech
Electrical Tech
EFI Tech
Classic TECH- specs, codes, resto issues FORUMS
60 & Older Pontiac TECH
61-63 Tempest & LeMans TECH
61-66 Big Pontiac TECH
64-65 GTO Tempest & LeMans TECH
OHC-6 TECH
66-67 GTO Tempest & LeMans TECH
67-79 Big Pontiac TECH
67-69 Firebird TECH
68-69 GTO Tempest & LeMans TECH
69-71 Judges only TECH
69-77 Grand Prix TECH
70-72 GTO Tempest & LeMans TECH
71-77 Ventura including 74 GTO TECH
73-77 A-body TECH
74-76 Firebird & TA TECH
77-81 Firebird & Trans Am TECH
1982-92 TA & FB TECH
78 and Newer G-body Pontiac TECH
2004-06 GTO & 2008-09 G8 Tech & Chat
Other models Pontiac Tech
General Late Model Tech
PY Welcomes 1993-02 Firebird/Trans Am Owners
93-02 General Tech/Discussion
93-02 Interior Tech
93-02 Exterior Tech
93-02 Engine Tech
93-02 Transmission Tech
93-02 Exhaust Tech
93-02 Race Tech
93-02 Electrical Tech
93-02 Suspension Tech
93-02 Wheels/Tires
1993-02 Firebird/Trans Ams FOR SALE/WANTED
1993-02 Firebird/Trans Am Parts FOR SALE/WANTED
PY Welcomes 2004-06 GTO Owners
04-06 General Tech/Discussion
04-06 Interior Tech
04-06 Exterior Tech
04-06 Engine Tech
04-06 Transmission Tech
04-06 Exhaust Tech
04-06 Race Tech
04-06 Electrical Tech
04-06 Suspension Tech
04-06 Wheels/Tires
2004-06 GTOs FOR SALE/WANTED
2004-06 GTO Parts FOR SALE/WANTED
PY Welcomes 2008-09 G8 owners
G8 General Tech/Discussion
G8 Interior Tech
G8 Exterior Tech
G8 Engine Tech
G8 Transmission Tech
G8 Exhaust Tech
G8 Race Tech
G8 Electrical Tech
G8 Suspension Tech
G8 Wheels/Tires
2008-09 G8s FOR SALE/WANTED
2008-09 G8 Parts FOR SALE/WANTED
BUY, SELL, TRADE Classic PONTIAC "PARTS"
61-77 GTO, Tempest & LeMans Parts For SALE
61-77 GTO, Tempest & LeMans Parts WANTED
Big Pontiac (incl G-body)Parts For SALE
OHC 6 Buy/Sell/Trade
Big Pontiac(incl G-body)Parts WANTED
67-81 Firebird & TA Parts FOR SALE
67-81 Firebird & TA Parts WANTED
1982-1992 TA & FB parts FOR SALE
1982-1992 TA & FB parts WANTED
LS Parts for Sell/Trade
All other Pontiac parts for sale/wanted
Collectibles FOR SALE
Collectibles WANTED
SOLD Parts
BUY, SELL, TRADE Classic PONTIACS
Big Pontiacs(including G-body) FOR SALE
Big Pontiacs (incl. G-body) WANTED
61-77 GTO LeMans & Tempests FOR SALE
61-77 GTO LeMans & Tempests WANTED
67-92 Firebirds & Trans Ams FOR SALE
67-92 Firebirds & Trans Ams WANTED
All Other Pontiacs FOR SALE
All Other Pontiacs WANTED
SOLD Pontiacs
11:09 AM
-- Responsive 2017
-- PY Online 2015
-- Late Model - Blue
-- Default Style
---- PY Forums (green)
-- Test
-- 100% Default
Contact Us
Home
