Old 05-12-2024, 08:04 AM
Held for Ransom's Avatar
Default Window crank
The wife questioned me about the '73. She asked if someone messed with the window cranks. She found it stupid the crank stops straight up when in the up position. What have others seen (untouched/restored)?
ID:	633599   Click image for larger version
ID:	633600   Click image for larger version
So long, farewell.
Old 05-12-2024, 09:34 AM
My 73 TA was power windows so no help, but I'd say that is not factory position?
I'm pretty sure all my other Birds had the handle facing forward when window up all the way.
Old 05-12-2024, 11:15 AM
RAJ7395's Avatar
RAJ7395 RAJ7395 is online now
Isn't the regulator input shaft splined? If so, you can pop the handles off and re-clock them to whatever end position that you want.
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int
1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int
1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int
Old 05-12-2024, 11:39 AM
I know that. But, if that's the way it was installed at the factory, why change it?
So long, farewell.
Old 05-12-2024, 03:46 PM
Norwood's Avatar
Norwood Norwood is online now
I always thought 10 o’clock was correct
Old 05-12-2024, 04:03 PM
Ramairnacho Ramairnacho is offline
factory error, should fix for wife. Her happiness is better than a stupid factory error. I'd put it at 3 or 4 o'clock!
Old 05-12-2024, 05:49 PM
SD73's Avatar
SD73 SD73 is offline
I thought I read somewhere that the handles were supposed to be at the 9 O'Clock position (pass side) 3 O'Clock (drv side) when the window was closed. Where it stopped when open was based on that.
Old 05-12-2024, 06:12 PM
Norwood's Avatar
Old 05-12-2024, 07:05 PM
SD73's Avatar
You may be right. I may be thinking MoPaR.
I did a check in the Assembly Manual and didn't find any reference. The closest I can get is looking at some old Firebird coffee table books from back in the day and I just saw one shot of a bird with the crank in the 8 O'Clock position. I checked some factory brochures from all lines on Pontiac and I didn't seen any clear shots of bird cranks, but I did see a Catalina with a crank in the 8 O'Clock pass side position and another car with a drivers side at 4 O'Clock.
The Following User Says Thank You to SD73 For This Useful Post:
Old 05-12-2024, 07:33 PM
GREGGDOG GREGGDOG is offline
Agree with 4 o'clock driver's and 8 passenger. I looked into this years ago, checked out a lot of original cars, maybe even here. Pontiac got a lot right with these cars including the most natural crank position to roll down your window.
Old 05-12-2024, 11:07 PM
Default My 70
This is position of my 1970 never removed door panel passanger side pic. We have owned since 78. Looks like 10 o'clock. My parts car 70 400 esprit is very original and same position with windows closed but there is a loose tolerance by design and will look like it's 12 ish. I believe if you push it down it will rest at 10 o'clock. my 1st was a guess my error. They both move to 12 o'clock with out putting force on windows arms
ID:	633662   Click image for larger version
ID:	633663   Click image for larger version
Old 05-13-2024, 04:18 PM
Transamric's Avatar
How about 10:15? Not helpful???
