Old 05-10-2024, 02:24 PM
scott06 scott06 is offline
Default Block Date Code - too close to build date?
Trying to determine if this is too close to car build date to be considered correct-
I have a 65 GTO convert that I bought in 1990, as a non running project car. I knew it was a stick shift, but later when I got the PHS I found out the car was originally a 3x2 4 spd so I have been trying to find a date code correct WS block for it. I have found a couple but all have been too $$$ or issues like already bored .060 or etc.
I have found one that is std bore, magged, guaranteed ok but I am worried the date code is too close to my build date.
Car cowl tag is 01D (4th wk of Jan 65)
Billing sheet from PHS has build/invoice date as 1/29/65
Casting date on block I am looking at is 1/26/65
Car was built at Pontiac plant where all engines were built.
Is this too close to be considered date code correct? The answers I have gotten is this is atypically close but could be considered correct.
I am just doing a driver not a show car, and have no intentions should I sell of representing it as original just date code correct replacement block
One of the previous owners must have had two 65 GTOs as it came with a WT code engine that was cast in June or July. Was thinking I could rebuild a correct WS code engine and eventually sell the WT code engine as it is a runner
Old 05-10-2024, 02:41 PM
Cardo's Avatar
Cardo Cardo is offline
Not too close at all. I had a 66 GTO, Pontiac plant build. Engine built Nov. 8, car built Nov. 11. Totally within the scope of normal for that plant.
"I know just enough to keep me here, but not enough to get me out"
The Following 2 Users Say Thank You to Cardo For This Useful Post:
Old 05-10-2024, 03:43 PM
