Old 04-20-2024, 05:17 PM
LET LET is offline
Default PVC and valve covers
I have a 67 GTO, I’m trying to figure out the PVC routing. There is A grommeted hole in the right valve cover top. According to my manual, it shows two hoses going into the intake manifold and into the PVC valve in the rear of the manifold. My manifold has proper two holes, but the PVC valve is in the front of the manifold not the rear. So I guess the manuals wrong because my intake is off a 67. I also need to know what to do with the right side valve cover hole. I’ll attach a picture if I can. have my intake.
Old 04-20-2024, 08:01 PM
242177P's Avatar
242177P 242177P is offline
Originally Posted by LET View Post
So I guess the manuals wrong because ...
Don't blame the manual, your valley pan
is off of a later model. If you're looking for
correctness, get an earlier one. Simple.
Old 04-20-2024, 09:55 PM
indymanjoe's Avatar
couldnt you connect the pcv valve to the fitting on the manifold by the number 2 in your pic? thats a dual plane fitting i think.
Old 04-20-2024, 10:41 PM
LET LET is offline
Thanks guys. I figured it out. Your help is appreciated.!
Old 04-25-2024, 06:11 PM
geeteeohguy's Avatar
Here's my original '67 PCV set-up. Two lines running from both planes of the intake to a 'Y' fitting and the hose going to the rear of the valley pan, where they go into the pan at the grommet. NoClick image for larger version
ID:	632643 valve cover PCV used in '67.
Jeff
