Old 03-30-2024, 09:50 PM
grivera's Avatar
grivera grivera is online now
Default Ames Performance Core Support
Ok, it’s 2024 and Ames lists this core support in the catalog and website but no indication if it needs modification. Usually they have notes for items. Further no side view photo to illustrate if it has the 9-10 degree angle like OEM. Has anyone used one recently and can advise if this fits a 69?
https://www.amesperf.com/parts/17124/
Will Rivera
‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded)
Old 03-31-2024, 04:40 AM
dataway's Avatar
dataway dataway is offline
Guessing it's the same messed up part being sold for 20 years. If it was a "new improved" part it probably wouldn't be getting discounted.
Shame, what a pain to fix the way they are.
I know if I had it to do all over again I would have used the re-pop part as a donor for patches to repair the original.
Old 03-31-2024, 07:57 AM
grivera's Avatar
Thanks - I guess I’ll call Ames tomorrow morning and ask to be sure - damn shame they don’t say one way or the other
Will Rivera
Old 03-31-2024, 01:48 PM
grivera's Avatar
This is my current situation- the driver’s side is significantly worse. I may attempt to fix it with my extremely limited welding skills.
ID:	631423   Click image for larger version
Will Rivera
Old 03-31-2024, 03:07 PM
roger1's Avatar
roger1 roger1 is offline
Yours looks pretty close to the way mine did.
https://forums.maxperformanceinc.com...38#post6242738
Follow on from this post until I sprayed the core support with epoxy primer.
'69 GTO Convertible - Acquired October 2020. An all original project car. Restomod is underway PROJECT THREAD
'83 Chevy Choo Choo SS El Camino - LT1 350/4L60e, Owned for 30 Years, completed 2nd restomod in 2018 PHOTO
2019 BMW 440ix - Twin turbo I6, 8spd auto. PHOTO
'55 Chevy Bel Air Sport Coupe - Ram Jet 350 / T56 Magnum 6spd, Restomod Completed Sept. 2012, Sold Sept. 2021 PHOTO
Old 03-31-2024, 05:14 PM
dataway's Avatar
That's fixable for sure, I've seen way worse come back to life. How's the top?
Old 03-31-2024, 06:02 PM
grivera's Avatar
Thanks, Roger!
Dataway- from what I can see the top looks fine but I don’t have fenders off yet
Will Rivera
The Following User Says Thank You to grivera For This Useful Post:
Old 03-31-2024, 10:37 PM
Seems like guys have been saying the top shelf is based off 1968 design
