Old 03-23-2024, 01:13 PM
Falkon Falkon is offline
Default Power Window Switch on 1980
Does it matter which way it's installed? Is there a top or bottom? I didn't pay attention when I took it out. Fits either way.
Old 03-23-2024, 01:16 PM
I'm not positive, but if the wires connect either side, that would determine the 'Up' or 'down'? One wire is probably down and one is up.
Old 03-23-2024, 02:36 PM
Thank you. I checked it w/ a meter. All it does is hook onto the wire connector. The switches seem to connect the same terminals. Just verifying. Don't want to pop a fuse or CB.
Old 03-23-2024, 08:27 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Plug only goes on one way as there is a locating prong to make it only go one way.
Skip Fix
