Old 02-07-2024, 09:08 PM
LET LET is offline
Default 67 gto wiper motor not working
It works if i run clip wire from + post on battery and a clip wire from - terminal to motor. Plug it in to the car, nothing. Power is there when i turn on wiper switch, so its getting power. Won't run. Whats going on???
LET
Old 02-08-2024, 12:01 AM
242177P's Avatar
242177P 242177P is offline
"Power is there". What about ground? It worked when it was hooked up to negative. When motors use mounting points for ground, paint can easily interfere
Old 02-08-2024, 12:04 AM
If I recall correctly, the wiper is one of those things that are turned on when a ground is provided... similar to the interior lights where 12 volts is always present on the light but the ground is provided by the door switch.
Old 02-08-2024, 11:33 AM
GoGoat GoGoat is offline
The hot + wire is present at motor when key is on. Dash switch delivers the ground - to the motor. Motor case ground is there for it to continue to the park location after dash switch is turned off.. Hope this helps.
The Following User Says Thank You to GoGoat For This Useful Post:
Old 02-08-2024, 02:15 PM
LET, have you tried putting the negative jumper to body ground instead of battery negative? I'm talking about when you put the positive wire to the positive terminal of the battery.
Old 02-09-2024, 12:06 PM
Hammertime Mike's Avatar
Hammertime Mike Hammertime Mike is offline
Send a message via ICQ to Hammertime Mike
I ran into what was a grounding issue with the wipers in my 67. At the time it was a new car to me. I got mine to work as you did. Mine ended up being a missing ground, A flat metal that fit to the wiper motor and headlight switch. I only realized the missing part when looking at a dash cluster that I had. Once I added this the wipers worked properly. Hope this helps.
Old 02-10-2024, 01:26 PM
Peter Serio's Avatar
Peter Serio Peter Serio is offline
Default The wiper switch ground strap
Here is a photo of a 66 Lemans dash bezel, the ground strap for the headlamp switch + the wiper/washer switch is highlighted in blue.
The '67 GTO/Lemans ground strap has one tiny bend in it that is different from a 66 but the overall mounting and location of the strap is the same.
Name:	66 GTO non rally gauges_Ground strap_A~.jpg
Peter Serio
Owner, Precision Pontiac
The Following 2 Users Say Thank You to Peter Serio For This Useful Post:
