Old 01-23-2024, 07:10 PM
grd777 grd777 is offline
Default need a reverse back up switch
looking to buy a reverse back up switch for a Muncie m 20 tranny .or where can i buy one
Old 01-24-2024, 03:20 PM
Mr. G Mr. G is offline
For what car?
Old 01-25-2024, 04:04 PM
Formulabruce's Avatar
Your 1972 Firebird.
This switch is on the steering column, near the base. I'm pretty sure Ames has them. This switch is actuated by the back drive linkage.
Old 01-25-2024, 04:15 PM
Your 1972 Firebird.
thanks Bruce my car was converted to a 4 speed with a m20 . is the switch the same .
not sure what you mean about the back drive linkage. do u have a photo
Old 01-25-2024, 04:22 PM
pontiacstogo's Avatar
pontiacstogo pontiacstogo is offline
Lots of pictures in this thread;
https://forums.maxperformanceinc.com...d.php?t=870388
Often missing due to header fitment problems or not included during an auto to manual swap. It is a series of rods that operate when the shift lever is moved into reverse. Engages the reverse lights via a switch in the base of the steering column. Also works with the reverse lock out function to lock the car in reverse when the ignition is turned to the lock position.
Peter
1974 Trans Am, 400 4-speed, 3.42 rear.
The Following User Says Thank You to pontiacstogo For This Useful Post:
Old 01-25-2024, 04:45 PM
have that all in place .just want to confirm is the switch at the tranny or under the steering column
Old 01-25-2024, 10:30 PM
Here is a pic of a Factory 1970 4 speed column. Switch is what you see on it . This comes on when car is in reverse AND Key is able to come out once engine is off. Its only a 2 pin connector. To do a conversion correctly you need a bunch of backdrive linkage And this switch and connectors for it. You can use an auto harness by just using the 2 wires for reverse that are on the combo neutral safety switch, and replace switch with smaller std switch with reverse only.
Neutral safety is accomplished by the clutch switch.
This column is Hanging upside down by the lever that moves this switch and hooks to the backdrive.
Old 01-25-2024, 11:51 PM
will check my car and see what i have
Old 01-28-2024, 11:47 AM
yes i have this same switch ,but can not seem to see any wire for this .how does it look like
Old 01-28-2024, 12:42 PM
bhill86's Avatar
bhill86 bhill86 is offline
Not sure about earlier years but pink and green in later.
1977 Trans Am 400/4speed (swap)
Brian
Old 01-28-2024, 08:30 PM
i think i found it ,but mine is orange and pink
Old 01-28-2024, 08:54 PM
bhill86's Avatar
Double check it. I just found my 72 diagram and it shows pink/blk and lt green.
Brian
Old 01-29-2024, 05:31 PM
i checked again i see orange and pink will take a photo and post
