I think I found the perfect header fabricator!
Wish I knew who made these!
" Darksiders Rule "
Just because you can…..doesn’t mean you should.
The Following User Says Thank You to b-man For This Useful Post: | ||
Tuned headers; for that last tenth of a horsepower.
Ed 1968 GTO (Thanks Mom) 2006 Silverado 2007 Cadillac SRX 2015 Chevy Express ![]() 2024 Cadillac LYRIQ |
The Following User Says Thank You to OG68 For This Useful Post: | ||
Them calculations were intended to be foolproof.
The Following User Says Thank You to Half-Inch Stud For This Useful Post: | ||
Extra long tubes because a T bucket is so heavy it needs a lot of bottom end torque!
Set that baby up at about 15.5:1 AF ratio and enjoy all those pipes in cherry red! Would be impressive on a summer night at the cruise in.
The Following 2 Users Say Thank You to mgarblik For This Useful Post: | ||
[QUOTE=misterp266;6474846]I think I found the perfect header fabricator!
"Wish I knew who made these " That's easy, " Spider-Man ". |
Plumbers nightmare!Tom
Torque peak at about 1,500 RPM.
The Following User Says Thank You to Jack Gifford For This Useful Post: | ||
Hey guys they went to “great length”s to make those. :-) . Like 400 ft of tubing!
Happiness is just a turbocharger away! 960 HP @ 11 psi, 9.70 at 146. Iron heads, iron stock 2 bolt block , stock crank, 9 years haven't even changed a spark plug! selling turbos and turbo related parts since 2005! |
The Following User Says Thank You to turbo69bird For This Useful Post: | ||
Doesn't even need mufflers.
GT |
Helmholtz Resonance Formula says ..... AHHHHHHHHH!!
I'm World's Best Hyperbolist !! |
The Following User Says Thank You to dataway For This Useful Post: | ||
Advertising for his Tubing Manufacturing company.
Tom V.
What are your plans for the weekend? “I’m going to see if I can figure out how to remove my headers”.
How ‘bout some straight pipes?
" Darksiders Rule "
It's hard to be sure but I believe they're 180 degree equal length headers. Which are ideal to warm your hands and dry wet gloves during those Christmas time cruises to the toboggan hills.
If it breaks. I didn't want it in the first place. _____________________________________________ 69 GTO \ 72 FIREBIRD \ 1/2 OF A 64 GTO \ 70 JAVELIN \ 52 FORD PU \ 51 GMC PU \ 29 FORD PU \ 85 ALFA ROMEO SPYDER \ A HANDFUL OF ODD DUCATI'S \ 88 S10 LT1 BLAZER & MY DAILY DRIVER 67 SUBURBAN. |
There's more than one way to cheat that pesky 105 dB rule at the track.
The Following User Says Thank You to VCho455 For This Useful Post: | ||
That's got to be the oldest "hot-vee" setup I've ever seen!
![]() Quote:
It's tough to be sure but I'd make a small wager that some of those tubes are crossing in front of the engine.
