Old 12-07-2023, 11:19 PM
MatthewKlein MatthewKlein is offline
Default AN fitting question
Hello all,
I have been searching for a T fitting with the following configuration
#1 3/8npt
#2 -8 swivel as in position #4
#3 -8 male
Is such a thing available or do I just use a swivel union in position #2?
Thanks, Matthew
Name:	an fitting.jpg
Old 12-08-2023, 01:36 AM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
You could also do a Tee with swivel at #2 and then use an NPT-swivel adapter, but that would make the assembly longer. These are Parker part numbers. Also take note of how the ports are numbered on a Tee (3 is the branch).
ID:	624669   Click image for larger version
The Following User Says Thank You to hgerhardt For This Useful Post:
