Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 12-04-2023, 12:21 PM
harry k's Avatar
harry k harry k is offline
Send a message via AIM to harry k Send a message via MSN to harry k Send a message via Yahoo to harry k
Default Solid Roller Camshaft What do you have?
What do you have for a solid roller in high 269 to 279 area preferably 110 LSA
.440+ to .455 lobes 50mm stock block.
Old 12-17-2023, 11:24 AM
harry k's Avatar
meant 48mm stock block
also can use duration @50 259+
Old 12-17-2023, 07:00 PM
Tom Vaught's Avatar
Boost Engineer
I have Marty Palbykins "Back-up" 400 Pontiac Camshaft (when he ran 6.96 and 206 mph in the quarter.
Timing is not good thought as I am moving and the camshaft is in a safe spot in my new barn. The question is where in the barn is the camshaft.
It might also be more duration than you are requesting. Sorry Harry.
It fit a heavily modified 1967 stock Pontiac (2 bolt main block converted to splayed main caps).
Tom V.
Old 12-18-2023, 02:04 AM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
I have a Cam Motion solid roller that's 269/272 with 108 sep. Cam card below. But it's only got .370/.381 lobe lift.
Old 12-18-2023, 08:43 AM
AG's Avatar
AG AG is offline
I have an Ultradyne 280/290@0.050" with 0.426" lobes and a 108 LSA. I have to verify the lobe specs.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
Old 01-07-2024, 11:38 PM
harry k's Avatar
TTT
Old 01-08-2024, 02:32 PM
ChiefCrazyCanuck ChiefCrazyCanuck is offline
Default Std. Journal Pontiac Roller
I have a 272/280 110 LSA with lobe lifts of .480 and .487 respectively.
Old 01-25-2024, 01:29 AM
harry k's Avatar
PM sent.
Old 01-25-2024, 01:31 AM
harry k's Avatar
Bump as well.
Old 01-25-2024, 10:13 PM
Ross455 Ross455 is offline
I have comp 272 / 278 @ .050 on a 108. Has .420 lobes
