THE LOBBY A gathering place. Introductions, sports, showin' off your ride, birthday-anniversary-milestone, achievements, family oriented humor. |
Car trailer winch battery?
I need to replace the battery on the trailer winch,
. Some have recommended a deep cycle while others have said to get a regular heavy duty battery. The winch is a Warn, but an old one and I will be loading a 1939 Pontiac 4 dr sedan on an 18ft open trailer. What batteries and brands do you all use?
Remember no one is perfect. Everyone's butt has a crack in it! |
I don't have a dedicated winch battery. For unloading, I just use the trailer's small breakaway-braking battery. For loading I idle the tow vehicle and use its system to power the winch. This doesn't require any switching, since the full-time voltage through the trailer connector is always routed to the trailer's braking battery (to keep it charged).
Responded on the HAMB as well, but just in case.....
I also do NOT use batteries on either trailer. Since both my transporting trucks are diesels with dual batteries I just ran a number 2 cable from the batteries back to the rear bumper of each truck with a 175 amp marine/NASCAR plug under the bumper (as shown below) the plugs are the same on both trucks & both trailers, so it does not matter which combination I am using. Doing it this way once is so much easier than messing with a battery in or on the trailers, removing, charging, etc,etc. God Bless Bill https://www.jalopyjournal.com/forum/...closed.614419/
Your QUALITY Pontiac Transporter Since 1983 Bills' Auto Works Est 1983 & still going strong! 1955 Chevy Altered W.B. Gasser 1955 Nash Ambassador Custom Lemans 1964 Grand Prix 1966 Catalina Conv. 421+ 1966 Ambassador DPL 2dr HT 1966 Ambassador Cust. 2 DR HT 1967 Marlin 1967 Toronado 1973 Nova Full Chassis Car 1992 Jag XJS Conv 1992 Jag XJS Coupe 2007 Cad XLR-V Supercharged Roadster |
If you do use a trailer battery, my understanding is a Deep cycle. I have an Interstate. Mine is charged from the truck through the RV plug. The Trailer small breakaway-braking battery is strictly for the electric brakes on the trailer, it is too small for any winch in my opinion. There is lots of folks who forget to check this battery each year.
I run a big ass deep cycle battery on mine. It runs a 12k lb winch, and has pulled some heavy stuff, including cars that have no wheels or suspension and sunk in the mud, lifted full size 1 ton trucks, off road Jeeps etc etc.
I throw a trickle charger on it every now and then, and it's always been ready for work.
The Following 2 Users Say Thank You to 72projectbird For This Useful Post: | ||
SWEET wiring set-up. Will be doing the same on my older Cummins Dodge, am not enamored with the winch & current battery positioning on the triangulated nose of my open car trailer.
The Following User Says Thank You to 'ol Pinion head For This Useful Post: | ||
For your Warn winch and loading that '39 Pontiac, a deep cycle battery is probably your best bet. They're great for long-term use and don't drain as quickly. By the way, I've had some luck finding trailer gear at a place called boomandbucket. Might be worth a shot to see if they've got the right battery for you.
The Following User Says Thank You to joelau27 For This Useful Post: | ||
I bought a deep cycle AGM battery from Sam's club. Works great so far. I've had it for 3 years and no problems yet.
"I know just enough to keep me here, but not enough to get me out" |
The Following 3 Users Say Thank You to Cardo For This Useful Post: | ||
I use a setup like Bill's usually, but I just use a cheap Rural King car battery when I am using a different tow vehicle. My open trailer usually uses a cheapie HF winch that i got over a decade ago. It is removed and stored inside when not in use. I took it apart when it was new and loaded it up with the proper grease, they had just enough in there from production to keep it from throwing sparks. I'll admit, I've subjected the poor thing to near stalling over and over, it just keeps working. I've had it long enough that I had to replace the cable!
My enclosed trailers have decent winches and inexpensive, car batteries - which are charged by the towing vehicle as we zip along the hiways and byways of America. I do like that capability. The most off-the-hook winch I had was a giant Warn that I had on a three axle equipment trailer, it had the biggest 12v battery I could find. The winch had 1/2" cable AND a pulley block for those tough situations. I went to get a derelict chevy truck out of the woods once, it broke the damn truck in half. There's a local acquaintance with a hydraulic winch on an old F250, and I saw him pull out a six axle dump truck near a ravine close to my house. Had five pulley blocks set to various places, and had out hundreds of feet of cable. I was looking for the safe place to stand in case the cable broke, then quickly realized the horror that would be thrust upon the EMS personnel that would arrive on the scene to see multiple decapitated bodies in the event it let loose. I sat in my truck with the doors closed, just in case!
Clutch Guys Matter _______________________________________ 53 Studebaker, 400P/th400/9" 64 F-85 72 4-4-2 Mondello's VO Twister II 84 Hurst/Olds #2449 87 Cutlass Salon 54 Olds 88 sedan |
The Following 4 Users Say Thank You to Mr Anonymous For This Useful Post: | ||
I use a Deep cycle battery for the winch however, I also have my breakaway switch wired to it as well. No reason to run 2 batteries. I ran the 12V from the Truck Trailer plug to the trailer battery terminal to keep everything charged as I drive down the road. Has been working well for 7+ years. Still same battery as well.
The Following User Says Thank You to DOC For This Useful Post: | ||
