Old 12-01-2023, 10:34 AM
FrankieT/A's Avatar
Default WTB 1971 NOS Heater control valve
Anybody have an NOS heater control valve for a '71 Firebird for sale? I'm not sure what years or body styles are the same but what I need has the mounting bracket attached to it. The replacement 4 Seasons one looks identical but does not have the mounting bracket. Any help would be appreciated.
Old 12-01-2023, 10:53 AM
FrankieT/A's Avatar
Actually after closer inspection the the bracket come off the valve, the valve has threads on it for a nut. But still looking for the correct valve.
Old 12-01-2023, 12:59 PM
78w72 78w72 is offline
Is this heater control valve only used on early firebirds? All the mid to late year 2nd gen birds Ive had didnt have a separate control valve, the heater core gets full hot water all the time and the inside temp is controlled by a flapper door in the heater core box.
Old 12-03-2023, 05:34 PM
FrankieT/A's Avatar
That is correct, as a matter of fact I believe all Pontiacs are like that with a mid Gen change...
Old 01-06-2024, 06:54 AM
Red80TA Red80TA is offline
1970 Assembly diagram, vacuum-operated heater tap with AC from 70-71 models, and fresh air vacuum door in the AC case of the 70-73 models. There was a limited run of reproduction mounting brackets for the tap a few years ago.
1970 Firebird heater tap vacuum operated evaporator case AC door (1) by Ben, on Flickr
#9774799
https://www.2040-parts.com/nos-1965-...alve-i1580779/
Here's an old thread :
https://forums.maxperformanceinc.com...=807846&page=3
Old 01-06-2024, 11:26 AM
Cammer-6 Cammer-6 is offline
bringing back nighmares of vacuum controls on my 71.
I never did find a diagram of hose schematic,just stumbled thru
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 01-07-2024, 07:36 PM
Whats part number of one you need?
#9774799?
