Old 11-29-2023, 10:55 PM
Shiny Shiny is offline
Default Control Arm Nuts - How Tight?
It's been a long time since I replaced the bushings and I left the nuts loose until I had the front bumper back on.
Is 50 ft-lbs correct for these nuts?
I want to avoid over-tightening and not sure if they self-limit or somehow compress correctly with a measured torque.
Mike
Old 11-30-2023, 06:41 AM
Kenth's Avatar
Kenth Kenth is offline
From 1970 Pontiac Service Manual Firebird Supplement.
ID:	624025   Click image for larger version
Name:	1970 Front End Torque Specs Firebird Supplement.jpg
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 11-30-2023, 12:50 PM
Thanks Kenth
Mine is a LeMans but spec is likely the same.
Old 11-30-2023, 02:00 PM
JLMounce JLMounce is offline
Full weight needs to be on the car before you torque those. Nose, engine, hood etc. I'd probably go as far as to make sure the radiator is in and full as well.
-Jason
1969 Pontiac Firebird
The Following User Says Thank You to JLMounce For This Useful Post:
Old 11-30-2023, 03:08 PM
Kenth's Avatar
Thanks Kenth
Not exactly the same, this is from the 1970 Pontiac Service Manual.
Name:	1970 Pontiac exc. Firebird Front End Torque Specs..jpg
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 11-30-2023, 05:20 PM
Thank you and understood. This stuff all happened this year, which is why the control arm bushings had not been tightened.
Thanks for taking the time to copy and post. The bushing nuts look like 50 ft-lbs. Hopefully it will be possible to get a torque wrench and socket on them at this point... I suspect it won't be as simple as it sounds.
