Old 11-06-2023, 05:14 PM
Doctor john Doctor john is offline
Default Parking lights
When restoring the dash in my 1967 LeMans, I replaced the dash harness and turn signal switch. The front, rear, and intermediate harnesses were replaced within the last couple of years. Everything works well but I noticed that the front parking/turn signal lights turn off when headlights are turned on. They work fine as turn signal and emergency flashers and as parking lights, but when the switch is pulled to turn on headlights they go out. Is this how they are supposed to work? If not, what could be the problem? I was going to check the bulbs to see if they are single or double filament.
Old 11-06-2023, 05:21 PM
OG68 OG68 is offline
Thats the way they were designed. 68 and after had the parking lights on with the headlights
2007 Cadillac SRX
Old 11-06-2023, 05:23 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
Thats the way there supposed to work. I believe there's a video on how to make them stay on by changing a wire on the headlight switch.
Old 11-06-2023, 05:29 PM
Thanks!
Old 11-07-2023, 06:52 AM
HALFWAY's Avatar
HALFWAY HALFWAY is offline
http://forums.maxperformanceinc.com/...=586289&page=2
Read post #22
I did this and it's simple and works like a charm.
I don't always cross thread the bolt - but when I do I run that bitch in with an impact until it's tight!
