Old 10-16-2023, 11:27 AM
RMMAN RMMAN is offline
Default Head Gasket replacement
I need to replace the head gaskets on my 69 RA IV engine. Should I go with the older design Fel-Pro #8518PT or one of the newer steel composite designs? I do not know what brand it is, but the ones in the Ames catalog appear to be the newer steel composite design. For me, reliability is much more important than the cost of the gasket.
Old 10-16-2023, 01:26 PM
74Grandville 74Grandville is offline
I would go with the Fel-Pro 1016 as the newer gaskets require a specific finish to ensure they seal properly.
1979 Firebird Trans Am 301/4spd (Now 428)
1977 Firebird Formula 400/Auto
2007 Grand Prix GXP 5.3L
Old 10-16-2023, 01:53 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Butler's head gaskets are the most reliable for a high performance street build.
Go fast, see Elvis!
Old 10-16-2023, 03:21 PM
Verdoro 68's Avatar
I used the old blue FelPro gaskets for years but went with the Butler head gasket on my recent build. So far so good. One advantage with the Butler gasket is that there is more material between the water path and the cylinder bore potentially mitigating a spot that could blow through. They're a little thicker - .045 vs. .039 on the FelPro.
Ken
'95 Comp T/A #6 M6 - bone stock (pics)
Old 10-16-2023, 03:26 PM
mgarblik mgarblik is offline
I have also had excellent luck with the Butler head gaskets. They are a black composite graphite gasket. I think they refer to them as the Fitzgerald gasket. I like the way you can build your own custom gasket set on their web site. Buying exactly what you want as far as materials, gasket thickness and such. Plus their intake front O-ring is thicker and the only one that will seal correctly. Their stuff is top notch and about the same price as Fel-Pro.
Old 10-17-2023, 01:50 AM
lust4speed's Avatar
Don't know if the gaskets are the same from years ago but the only real complaint with the Butler head gaskets is upon a freshen half the gasket stuck to the block and the other to the head mandating cleaning up both surfaces with a razor blade. Has that changed?
Felpro's leaves a little blue coloration on both surfaces that can be ignored. Lot less clean up work.
Mick Batson
1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 2+2 survivor AC auto -- 1965 Catalina Safari Wagon.
The Following User Says Thank You to lust4speed For This Useful Post:
Old 10-17-2023, 02:48 AM
Dragncar Dragncar is offline
Does ROL still make Pontiac head gaskets ?
I have had good luck with them. Both the performance set and their standard grey head gaskets have never failed me.
Old 10-17-2023, 12:06 PM
TransAm 474's Avatar
TransAm 474 TransAm 474 is offline
We have always had excellent results with the Felpro 1016's ... never have used the Butler gasket, so no experiance with those
1978 Trans Am
Pump Gas 461 Stroker
Old 10-17-2023, 01:32 PM
tom s tom s is offline
Have used the Butler gaskets for years.They make valve angle specific gaskets.Tom
Old 10-17-2023, 02:50 PM
jhein's Avatar
jhein jhein is offline
Nobody has mentioned Cometic head gaskets. Just curious as to what kind of situation would require that? The reason I'm wondering is because that's what my builder used on my motor, which is nothing particularly special.
Old 10-17-2023, 03:54 PM
No, that has not changed. They stick to both surfaces like crazy! I look at that as an advantage, not a problem. Gasket is doing it's job. Clean-up is a razor blade operation and a mess. But they seal. Cometic gaskets are great as well. Expensive and not needed for "normal builds" IMO. Both surfaces must be very smooth and within the surface roughness specs. they specify. So an expensive profilometer is recommended to measure block and heads before using them. We just bought one for the school. Mitsutoyo portable. Several thousand dollars for the tool.
Old 10-17-2023, 04:33 PM
Mr.Gasket makes a MLS head gasket for us.
https://www.holley.com/products/gask...ts/parts/5810G
They used to make their version of a Cometic, 120$ each but are discontinued.
I can find only a single in stock.
I have 2 I am saving.
https://www.lethalperformance.com/mr...ket-3250g.html
The Following User Says Thank You to Dragncar For This Useful Post:
Old 10-17-2023, 05:05 PM
Gach's Avatar
Gach Gach is offline
I know the Cosmetics are expensive, but you can get them in any thickness, and the beauty part is you can reuse them. I’ve reused mine twice. No issues…But hey to each his own. Mine are .52 thousands thick.
Old 10-17-2023, 05:42 PM
PAUL K's Avatar
Butler gaskets are still a mess. The trick is to put the shiny side down. That way the sticky part is on the head which makes clean-up a lot easier. Butler gaskets are correctly advertised as needing a re-torque. IMO all head gaskets need to be re-torqued regardless of how they are advertised. But that is a different subject.
Go fast, see Elvis!
Old 10-17-2023, 05:47 PM
Schurkey Schurkey is offline
Features:
Five layer (graphite core/perforated steel outer layers) composite construction
Graphite core has excellent thermo-conductivity-transfers heat away from hot spots in head preventing gasket burn-out
Provides excellent stability, compressibility and high temperature endurance
Coated with high temperature silicone to ensure sealing of engine fluids
That's not a Multi-Layer Steel (MLS) head gasket.
Advertised as MLS, but the (crappy) photo doesn't look like MLS to me.
Old 10-17-2023, 08:05 PM
Gach's Avatar
If cost isn’t and issue then definitely get the Cometic‘s.
Old 10-17-2023, 08:24 PM
Which may or may not require remachining of the block decks and heads to assure an appropriately-flat and smooth gasket surface.
Old 10-17-2023, 09:13 PM
Its a RAIV engine. Pretty much anything other than a Cometic will work fine.
Old 10-17-2023, 09:15 PM
How many heat cycles with 1016s and aluminum heads do you recommend a re-torque ?
Old 10-18-2023, 12:01 AM
Gach's Avatar
Cometic‘s. Don’t require you to re-torque the heads. I have never retorqued my heads on both builds. Never ever had a issue. Of course if you feel more comfortable on some else recommendation…then hey go for it. This is just my opinion but being able to reuse them is definitely a money saver. Plus they come off nice and clean.
The Following User Says Thank You to Gach For This Useful Post:
