Old 10-06-2023, 08:09 AM
KSZR KSZR is offline
Default 66 GTO brake pedal return
Noticed recently the brake lights staying on. Pedal isn't returning like it should. Eventually does after maybe 10 sec.
Brakes function normal, no pulling or dragging that I notice. Power drum brakes. 10 year old master cylinder.
Suggestions? Thanks!
Old 10-07-2023, 07:27 AM
Sounds like the MC to me.
Old 10-07-2023, 08:05 AM
Old 10-08-2023, 12:19 AM
Geoff Geoff is offline
Most inline brake boosters have a return spring inside, which might be broken. Not sure if your model does. Need to find an exploded view & check.
Old 10-08-2023, 02:38 AM
wbnapier wbnapier is offline
This?
Name:	Brake Pedal Return Spring 2.jpg
ID:	621230   Click image for larger version
Name:	Brake Pedal Return Spring 1.jpg
1965 Pontiac GTO
455/469 w/ #48 Heads, '65 Tri-Power
9.25:1 CR
Stump Puller Cam
Muncie M22W 1st-2.56 2nd-1.75 3rd-1.37 4th-1.00
3.55 Rear Differential
Front: 225/60R15 Height: 25.6"
Rear: 275/60R15 Height: 28"
Old 10-08-2023, 11:42 AM
I'm pretty sure he's referring to the spring inside the master cylinder. If you have a master cylinder in a vice to bleed it, it has a pretty strong pushback. If the pedal isn't coming back that's the first thing that enters my mind. Either the piston is rusted stuck or perhaps the spring is broken as Geoff mentioned.
Not saying that I'm right but it's the first thing I would check.
Old 10-08-2023, 04:22 PM
Cammer-6 Cammer-6 is offline
try a little heavier spring on the pedal assembly first
its pretty easy to get to vs the MC one.
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 10-08-2023, 05:03 PM
242177P's Avatar
242177P 242177P is offline
Spring on the pedal assembly is a manual brake
only deal. If a power brake master cylinder is no
longer capable of performing it's duties...
Not stopping where you're supposed to is quite
a disconcerting feeling
Old 10-08-2023, 09:34 PM
Thanks guys. More likely the master cylinder(spring) than the booster(spring)?
Booster would be original.
Old 11-25-2023, 11:19 PM
It stopped sticking...
Old 11-26-2023, 12:20 AM
ZeGermanHam's Avatar
Odd. It's probably going to stick again soon, though.
Just want to reiterate what others here have stated, which is that since your car has power assist brakes, it does not use a return spring on the pedal assembly. The spring responsible for returning the pedal is inside the master cylinder. My hunch is that the piston bore in the MC is not in great shape and is not allowing it to move freely all the time.
1998 BMW 328is (track rat)
Old 11-26-2023, 01:12 AM
Nope, the pedal return spring on power brake cars is inside the booster, not inside the m/cyl.
Good pic of it Zazarine's resto book, p. 219
