EFI Tech All things EFI and making classics modern!
Old 09-24-2023, 12:44 PM
First Bird's Avatar
First Bird First Bird is offline
Default New Fitech Harness - Wrong Connector
Fitech replaced the ECU and harness. Wiring from the ECU that is causing the problem is the six pin connector on the right in the photo. Four pin connector from the ECU is fine. The old harness had a two pin connector.
I’m prepared to make my own 2-pin connection. I’m assuming small orange from ECU goes to big orange wire. (I already have an external relay for the fuel pump.)
Big question then, which color wire from the six pin connector goes to the big red wire?
- Tom
