Old 09-11-2023, 03:03 PM
ScottU's Avatar
ScottU ScottU is offline
Default Single Booster Quadrajet
Anyone ever see a single booster Rochester Quadrajet with no number stamped on the side?
Old 09-11-2023, 03:15 PM
Does this carburetor have a spot for a round tag on the side?
Clay
Old 09-11-2023, 03:18 PM
ScottU's Avatar
No round spot for embossed tag
Old 09-11-2023, 03:43 PM
Kenth's Avatar
Kenth Kenth is offline
A (SR) 7041263 with the number grinded away?
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 09-11-2023, 06:42 PM
ScottU's Avatar
No grinding marks. Missing vacuum ports on front as well
Old 09-11-2023, 11:15 PM
JSuchma JSuchma is offline
FWIW.......I have had many 69 SR Quadrajets with partial numbers or no numbers at all. In fact, I have a 7041263 SR that has the "6" stamped over so many times it is unreadable.
Old 09-12-2023, 04:08 AM
Kenth's Avatar
7041263 is the only single booster unit w/o ignition vacuum port on front of bowl.
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 09-12-2023, 11:16 AM
Just pulled out my 7041263 after years in storage. I was mistaken about the number 6 being stamped multiple times. It is the 3 that has been stamped over. The bowl has all the vacuum ports, so I am wondering if it might be a 7041268 instead.
Old 09-12-2023, 05:00 PM
Kenth's Avatar
All factory 1971 single booster units fuel bowl has the same 7042572 cast # on back.
All but the 7041263 have the same secondary stamped # beneath fuel inlet.
SR 7041263 bowl have #7044603 cast on back, no secondary stamping.
HTH
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
