Old 08-09-2023, 09:16 PM
Default 1955 master cylinder
Has anyone installed a dual master cylinder on a 1955 Chieftain? It presently has manual brakes.
Old 08-10-2023, 04:56 PM
buds56's Avatar
buds56 buds56 is offline
I used a 73 chevy truck master cylinder on my 56 when I converted it to front disc brakes.
I made a bracket to hold and support the cylinder in the stock location.
This is the only pic I have, worked well, not show quality in appearance.
Used the stock pedal.
Old 08-10-2023, 11:19 PM
Any details that you can remember would be appreciated.
Old 08-11-2023, 05:24 PM
Bill Eveland's Avatar
Bill Eveland Bill Eveland is online now
I put one on the firewall where the defroster was
Illinois Outlaw Gassers
6.27@107
9.97@131
Old 08-11-2023, 10:19 PM
Where I live a defroster comes in real handy at night in late summer and fall.
Old 08-11-2023, 10:55 PM
We had a bracket setup that used the Wilwood remote master.
It bolts to the frame and uses the stock pushrod, lever, pedal, etc. Dual feeds for the master which bolts to the bracket:
https://www.wilwood.com/MasterCylind...ter%20Cylinder
The new owners may swat out a copy for you, contact scarebird.com
Old 10-28-2023, 01:20 PM
INchief INchief is offline
Sorry, looks like an older post. I used the parts from American Brake and Steering in California. Its a bolt in for the master cylinder, but needs a little "fitting" by the frame. It replaces the master cylinder with a new floor plate and pedal set-up. Won't fit on a manual transmission car due to the clutch pedal shaft being in the way. I installed the front disk brakes, as well. Kind of wish I had opted for the rear disks too. Works great with very little fabrication. Their customer service was excellent dealing with any issues, which there were a couple small things that came up. They have a lot of options if you check out the website - www.abspowerbrake.com
The Following User Says Thank You to INchief For This Useful Post:
