NA best horsepower factor
Survey. What is the most horsepower per cubic inch every achieved by any Pontiac NA
I think Picketts 428 made 2.64 HP per CI and backed it up on the track.Was a few year ago.Warp heads.Tom
How much better is that vs a real Pontiac head ? RAIV style or RAV
Canted valve Ford head on a Pontiac, meh. |
I think 2.30 to 2.35 is about it |
I would have to go back through the threads,was years ago.Stan might remember?Tom
► 428 * 2.64 = 1129.92 I don't know what the max HP the Picketts made was. I do know that many years ago you sent me 2 dyno sheets and max HP on one of those was 1019.1 @ 9400 RPM which is 2.38 Let me also add since it was talked about in a different thread. That was at a 600 RPM / second acceleration rate. Stan
Stan Weiss/World Wide Enterprises Offering Performance Software Since 1987 http://www.magneticlynx.com/carfor/carfor.htm David Vizard & Stan Weiss' IOP / Flow / Induction Optimization - Cam Selection Software http://www.magneticlynx.com/DV Download FREE 14 Trial IOP / Flow Software http://www.magneticlynx.com/DV/Flow_..._Day_Trial.php Pontiac Pump Gas List http://www.magneticlynx.com/carfor/pont_gas.htm Using PMD Block and Heads List http://www.magneticlynx.com/carfor/pont_pmd.htm Last edited by Stan Weiss; 07-15-2023 at 10:23 AM. |
The Following User Says Thank You to Stan Weiss For This Useful Post: | ||
No ra4 or ra5 has come remotely close that I'm aware of. Unless you can't Langer but his valves aren't straight any more either
Stan
Thanks Stan,that might have been it.Was a long time ago.I know the wagon was turning BIG RPMs through the lights.Tom
Do you know if Pickett's engine was a short deck block? I seem to remember it was. Either way, that that's an impressive number.
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
The engine was all alu short deck,large bore short stroke.It was a beast.I think they told me they were going through the trap at 10K.Tom
I am guessing I got this from you. Bore = 4.35" Stroke = 3.6" Rod = 6.2" Graph of HP from 2 dyno pulls Stan
Stan, can you provide the TQ Plot. I read into TQ vs RPM alot better. Reveals cam activity vs "optimal" activity.
I’m 2.27 per cube but I’ll line up against any other na Pontiac engine on small tires and drag their a$$.
A few years ago you posted. 870 tq @ 7000 and 1290 hp @ 8300 Are you over 1300 hp now? Stan
Sure not a problem. Stan
1307 with race oil at 8500 and 904 at 7000. Averages over 1290 in the power band with a single 4.
The Following User Says Thank You to John Langer For This Useful Post: | ||
You really kicked the torque curve in the arse. That is a 45 HP gain @ 7000 very nice. Stan
Just wondering what is the best HP per ci of a "normal" Pontiac engine ? I have not heard of any Warp-Cv engine making more power than Mikes engine, let along Langer. All the R&D that guy has done on his own dime he should get free AP stuff for life. I remember all those names from years ago that you thought were die hard Pontiac guys, only to end up with a Rat under the hood. Laid over valve or not, still a Pontiac. Took a Pontiac head and modified it. Not a Ford head and make it bolt on. There is a difference. |
Running engine or not, some say it was only a mock up. They would have changed things if just allowed to do it. Forward thinking. |
