Old 06-26-2023, 01:20 PM
PONTIAC LARRY's Avatar
PONTIAC LARRY PONTIAC LARRY is offline
Default 59 GMC 336
SO just curious on the 59 336 is supposed to be a small bore but same 3.75" stroke as the first 389 same tear so assuming also 3.0" main. Any chance the cylinder wall is just super thick then?
Is it a less bored out same casting 389 (very thick wall)
versus a
Different 59 casting with water jacket / cyl wall thickness to stay way under a 4 inch bore (3.78) ?
63 Catalina coupe 467 cid budget drag car 11's 1/4 , 7.20 1/8th pump gas n/a
66 Star Chief Executive 57k mile
69 Le Mans 2 dr HT 350 85k mile 15 sec 1/4
69 Firebird 400 Burgandy/Black
70 Olds Rallye 350 F85 4 speed 3.91's
70 Olds Cutlass Cruiser Red Wagon 350 101k miles 15 sec 1/4 12 sec w 455
74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8
2020 RAM 1500 SLT 4x4 5.7 A8 Hemi
2007 Hummer H3 3.7 liter turd
2019 Chevy Spark petrol car 38 mpg
Old 06-26-2023, 02:02 PM
tom s tom s is offline
I thought the 336 was a 58 engine?Tom
Old 06-26-2023, 02:46 PM
Supposed to be two different ones and the 58 336 was based off a small bore 370 with the same mains as the 370 same stroke and the 59 the 336 was now a smaller bore than the 58 and matching the longer stroke of the 389 at 3.75" and I suppose 3 inch mains. I think since posting this I found 59 336 casting number 350046 vs the 59 389 is 532000 3.78 bore so if as robust as the 389 perhaps at the least the 59 336 could literally use a STD 350 Pont piston in a rebuild bore .100 over makes it salvage able and stick later model 68 up 350 or 65/66 389 heads on it.
Old 06-26-2023, 04:00 PM
Bill Hanlon's Avatar
All the GMC (Pontiac) V8 engines had serial number starting with the displacement. So both a '58 and '59 engine's serial number would start with 336. Remaining serial number would tell the rest. '59 (389 based) engines are serial number 33635001 or higher, while the '58 (370 based) is lower. The serial number is on the passenger's side of the block.
In 58 the GMC block was bored to 3.875" giving a 336.1 cubic inch engine instead of Pontiac's 370. In 59 the GMC block was bored to 3.78" giving 336.9 cubic inches instead of Pontiac's 389. Crankshafts for both years had different part numbers that Pontiac. Maybe because of smaller (lighter) pistons???
Given a different casting number, I wouldn't depend on the '59 GMC 336 block being a 389 block that just wasn't bored as far.
Old 06-26-2023, 05:53 PM
Murf Murf is offline
I have a 59 gmc block setting in the garage. I could take a pic of the bores if it helps ya. It looks like a lot of room but IDK
Old 06-26-2023, 06:59 PM
Confirm 3in mains!Tom
Old 06-26-2023, 07:45 PM
694.1 694.1 is offline
It always seemed odd to me that GMC putzed with the displacement.
The only thing that makes sense to me is if motor carriers were taxed on displacement?
If it were a HP thing, it would be much easier to trim the HP. Heck, they used the Olds 370 too.
That would result in many more part #s than the Pontiac 370!!
But engineers do things for a reason...
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 06-26-2023, 07:51 PM
In some of the European markets road tax was determined by bore size so perhaps the GMC brand was being positioned to take better advantage of that.
Lots of early 4-bangers and V8s made for transport use (think Ford flathead) had extremely small bores and relatively long strokes to have lower taxable horsepower.
Old 06-26-2023, 10:30 PM
CATBIRD CATBIRD is offline
and so.....which was the infamous 1963 326/336???
Old 06-26-2023, 10:35 PM
It was the 1963 Tempest 326.
Those first year 326s had the 3.78” bore for 336 cubes. The next year they fixed it with a 3.72” bore for 326 cubes. GM corporate edict related to 10 pounds car weight to 1 cube of engine displacement, 336 was too much engine displacement I guess.
So it wasn’t a GMC truck V8 336.
Old 06-27-2023, 01:21 AM
blueghoast's Avatar
Can you bore a 4-cylinder to a .030 400 piston size?
I've got four good pistons from a earlier motor that
I would like to use in this 4-cyl build. Thanks for any info
GT
Old 06-30-2023, 08:39 AM
GT
I believe the extra thick 4 cyl block could go 090 over but the common regular one I would stop at a STD 400 piston at 060 over
Dave Johnson 63 Banshee can give more details on that
