Old 06-09-2023, 04:05 PM
drewm drewm is offline
Default RAR manifolds vs. others
Just looking for insight of the RAR manifolds, which everyone seems to acknowledge are the best ones made, versus the ones that our host sells. I've been trying for months to purchase a pair of RAR oversize d-port 64-67 as well as some accessories, but phone calls don't seem to work and now I am trying to order them on the website and it won't calculate the shipping so the order cannot be completed. I originally placed a verbal order back in February when they started coming back in stock. Then tried again in May and still have heard nothing.
Are the cheaper castings that much worse? I don't mind grinding the casting flash to pretty them up, but I was curious if there is any info on flow characteristics or is it so minor that it doesn't make much of a difference?
Old 06-09-2023, 04:37 PM
JLMounce JLMounce is offline
None of that really matters, because those manifolds are simply not available. They haven't been for many years. I would call them vaporware at this point.
I did speak with them about a month ago regarding long branch manifolds for 67-69 birds and it was the same thing I got years earlier. They had left sides, no right sides with an 8-12 week expectation, which is more than likely just a lie.
I don't think the produce you get from Ames is going to leave you stranded. Having the larger collector is nice, but that doesn't matter if, as stated above, the product isn't actually available.
-Jason
1969 Pontiac Firebird
Old 06-09-2023, 04:39 PM
steve25 steve25 is offline
How much hp are you looking to make and with what heads and in what body car will these be used in?
Old 06-09-2023, 04:40 PM
When I spoke with him in February, they were coming available, and again in May they were in and orders were being processed. They also show up as in stock on the website.
Old 06-09-2023, 04:41 PM
66 gto convertible. Just a run of the mill 461 with home ported 6x-4s. Not sure about HP, but I think 400+ should be do-able.
Old 06-09-2023, 05:12 PM
caveat emptor
-Jason
The Following User Says Thank You to JLMounce For This Useful Post:
Old 06-09-2023, 05:15 PM
unruhjonny's Avatar
400+ is doable on standard logs;
you don't even need a stoker motor to get there!
(iirc Dennis Jensen posted a dyno thread on a near stock 77-400 that did this)
1970 Formula 400
The Following 3 Users Say Thank You to unruhjonny For This Useful Post:
Old 06-09-2023, 05:24 PM
caveat emptor
Im getting that vibe no doubt. And lots of threads about it to back that up...
Old 06-09-2023, 05:27 PM
Sucks for sure, because the product is highly regarded. I'd been trying to buy long branch manifolds for over 5 years...a good bit before all the supply issues caused by the pandemic. Always the same song and dance, every time I'd reach out.
-Jason
Old 06-09-2023, 05:52 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Years ago we put a lot of effort into building a stock looking big power Pontiac engine using d-port exhaust manifolds. At the time we flowed every pair of reproduction manifolds available. The RAR' manifolds were not the best flowing. IMO their a great choice, high quality and convienant because you can get them with the 2.45 outlet that definetly helps with power.... But if they aren't availble there are other choices.
Go fast, see Elvis!
Old 06-09-2023, 06:10 PM
mgarblik mgarblik is offline
I had to change my entire build plan and go from round port heads to D-port because of the year's long round port long branch delays. I guess they never did happen and that was nearly 5 years ago now. I finally got a pair of D-port long branch from RAR. I have to admit, they are very nice, fit great, don't leak and look and sound great. But they don't make any power on a larger engine. My 468 Cu In. engine made almost 20 more HP and 30 more ft. lbs of torque on the dyno with the worst set of headers ever put on a Pontiac. Little 1 5/8" headers for a Pontiac 350 I had laying around. I guess you just have to pick your poison. At my age, I wasn't going to wait another 5 years or forever for exhaust manifolds.
The Following 4 Users Say Thank You to mgarblik For This Useful Post:
Old 06-09-2023, 08:04 PM
Our host sells 2.5 inch manifolds, part # N179GC, which I assume are similar to the 2.5 (2.45) inch RAR manifolds?
Old 06-09-2023, 08:06 PM
I dont mind waiting a little. I havent even started on my motor, so I have time. But I am trying to spread out the costs and when the RAR manifold seemingly came available, I thought it would be a good time to get them, before they go out of stock again for who knows how many years...
Old 06-09-2023, 08:44 PM
unruhjonny's Avatar
I’m going to be a counter point to that last post;
The shenanigans that cause supply interruptions are likely to not happen again any time soon.
1970 Formula 400
Old 06-09-2023, 10:08 PM
KSZR KSZR is offline
How did the rest compare?
Old 06-09-2023, 11:05 PM
PAUL K's Avatar
I wasn't aware they offered them with the larger exits.... Looks like you found a solution to your wait.
Go fast, see Elvis!
Old 06-09-2023, 11:07 PM
PAUL K's Avatar
Not sure I understand your question. We flowed them and used the pair we thought had the most power potential (highest flowing). We weren't really comparing them. The ones we used were purchased from a reproduction supplier.
Go fast, see Elvis!
Old 06-09-2023, 11:27 PM
You said you flowed every pair of manifold available right? I wondered what the results were?
The Following User Says Thank You to KSZR For This Useful Post:
Old 06-09-2023, 11:35 PM
PAUL K's Avatar
Yes we did. Some flowed better than others.
Go fast, see Elvis!
Old 06-09-2023, 11:42 PM
Funny
