Placement of Speedometer Cable Grommet
Hi anyone,
Which side of the grommet installs inside the interior? The wider or thinner side ? This is how I installed it but it’s been years since I had the speedo cable installed. And I can’t find my GTO Restoration Guide Thanks, Don
1966 GTO 1966 421-9.3-1 comp-Race Tec 23cc Pistons 1966 Tri-Power 1967 670 Heads Pontiac "Highlift" TriPower Cam by SpeedPro DUR 214 Int 224 Exh @.050 - 107 ICL LIFT .445" Int .465" Exh Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers 1966 Muncie Wide Ratio 4-Speed 1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears |
Cannot guarantee this is correct, done by Previous Owner when he converted car to 4 speed, but this is how the grommet looks from interior in mine.
Fort Worth/Dallas TX area 1966 GTO Fontaine Blue 389 CID Carter AFB Muncie 4 speed (orginally an automatic car) |
The Following User Says Thank You to ftwmlp For This Useful Post: | ||
Awesome! Thank you Ftwmlp
