Old 04-08-2023, 10:12 AM
Shiny Shiny is offline
Default Purpose of Vacuum Can?
Did all 1970 A-bodies have a vacuum can on the firewall?
What was the purpose? Do I need it for any reason?
I'm trying to get car running and am revisiting vacuum connections. A vacuum reservoir is not on my car and I don't know if it ever had one.
Car has AC and TH350. I added power brakes and replaced 2bbl with QJ. I just got QJ idling (tnx to shaker455) and plan to start with ported vacuum.
I have a tree on back of QJ base that accepts brake booster, transmission, and vent controls. QJ is Buick so vacuum ports may be different than those on a Pontiac carb. I plan to connect distributor vacuum unit directly to port on front of QJ.
I am not using the TCS solenoid.
Before I try to adjust idle speed or measure mechanical advance curve, I want to make sure a vacuum can wasn't needed. I have not yet measured idle vacuum, but expect it capable of over 15" with stock 350 and Summit 2800 cam.
Old 04-08-2023, 12:51 PM
The can is not needed for what your wanting to do.
The reserve cannister is to keep heat/ac/dash vents working properly when the engine is under load (low vacuum).
Clay
The Following User Says Thank You to "QUICK-SILVER" For This Useful Post:
Old 04-08-2023, 12:52 PM
Ahhh!
Thank you
