70 under dash wiring question
Trying to finish the dash wiring and not sure about these three connectors. First pic is single pink wire. Second picture is three terminal orange/black, red/white and pink. Third pic is 2 terminal orange/black and 2 yellow wires. Can't seem to find these on my wiring diagram. Any help would be greatly appreciated.
The connector #2 is for the ignition relay when you have power windows.
Connector #1 is probably the feed to #2 the connects to the fuse box. But I'm guessing on that one. I can't find #3 either
I built it one piece at a time and it cost me more than a dime. |
could #3 be rear window defrost either blower or heated glass ?
orange black looks like a heavy power wire
If your not at the table you're on the menu A man who falls for everything stands for nothing. |
That #3 connector with the double yellow wires. Since this is a 70 I wonder if this was for the electric seat back release. The large orange black is the power for accessories and the double yellows going to the 2nd door jamb switches.
iI do have power windows. So you're saying there should be a relay on the firewall that #2 plugs into?
Yes. If I can remember it is mounted to the column brace. Kinda high up.
I did some more searches on that relay and I think you're right, thanks for your help
I think I found the relay. it was bagged with the blower motor relay and other hardware for the evaporator case. Let me know if anybody thinks this doesn't look right. The last picture is the location of the relay.
