Old 03-24-2023, 08:05 PM
Gary H's Avatar
Gary H Gary H is online now
Default 79" T/A tilt column
I'm looking for a diagram of a 79' T/A tilt column. I have one I'm trying to replace the bearings on and I can't find the part numbers for the bearings. Can anybody help?
Old 03-25-2023, 03:25 AM
Trevor78 Trevor78 is offline
Which bearings? It's not as simple as supplying a diagram, you still have to go searching for the part numbers for each item. Do you need the diagram? Do you have the 76-81 Parts Manual?
Here's a diagram anyway.
Tilt Steering column diagram 1979_81 by Ben, on Flickr
Tilt Steering column diagram 1979_81 part numbers by Ben, on Flickr
Old 03-25-2023, 01:13 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Many diagrams for second gen columns show a bearing. None of my later even an 81 tilt Z28 column have a bearing, more a plastic bushing I couldnever find a part # for
Skip Fix
Old 03-25-2023, 05:57 PM
Gary H's Avatar
Thank you! Looking at the diagram above it appears that I need the bearing listed as #2. I don't have a 76-81 parts book so I can't look up the part number.
Old 03-26-2023, 01:10 AM
Possibly #26001827.
Old 03-27-2023, 08:08 AM
Gary H's Avatar
Possibly #26001827.
Thanks! I'll try that.
