Old 01-25-2023, 10:58 PM
tremo's Avatar
tremo tremo is offline
Question Side view examples of 275mm tire on 15x7 Rally IIs
Hi all,
I have new BFG 275/60R15s mounted on my 15x8 Centerline wheels, but I'm thinking about changing over to Rally II wheels for a more traditional look.
I found 15x7s at the junk yard (4" backspacing) and refurbished them for my MT DOT 255mm slicks, but I'm not sure if a 275 will fit on a 15x7, which are far easier to find used vs. 15x8s?
If 275s will fit on a 15x7 Rally II, can you share some side-view examples showing how far the tire sticks out from the rim? I'm thinking it may look too bulged out? If not, I only need one more 15x7 from the junk yard that I can refurb to swap over to the Rally IIs.
Pics attached are 275/60R15 on Centerlines and 255/60R15 Mickey Thompson DOT slicks on 15x7 Rally IIs.
Thanks!
Jim.
ID:	606043   Click image for larger version
ID:	606047   Click image for larger version
ID:	606049   Click image for larger version
* '69 Custom S - 2dr Hardtop Coupe - Rust-free Oregon survivor with all original panels and original trunk floor
* Engine alive and kickin' March 2nd, '06
* RA-IV 'spec' 400 (.060-over = 410ci), balanced, Comp Cams #9794041, #16 heads (72cc converted to large valve) with 1.65 Harland Sharp Rollers
* QuadraJet #7042210, HEI, Hurst V-Gate, FlowTech Headers, X-Pipe with dumps, Flowmasters, TH-350, 3.90 Posi
* Best ET: 14.06 - Bandimere Speedway, CO. @ 5,800+'
Old 01-25-2023, 11:11 PM
gtospieg gtospieg is offline
If you can find used 15x8's they are aftermarket....Pontiac didn't make 15x8 Rally II's...that's why they're hard to find.
Old 01-25-2023, 11:22 PM
tremo's Avatar
Ah! Well that makes sense!
Thanks.
Old 01-26-2023, 01:42 AM
The 275/60s are actually a pretty good fit in a 15x7” Rally II.
Look here: https://forums.maxperformanceinc.com...15&postcount=5
Old 01-26-2023, 07:26 AM
Formulajones's Avatar
Yep they fit fine, I've run 275's on 7" rims for decades on a few different cars, including my bird.
If you want an 8" rally II they are sold aftermarket.
https://youtu.be/XqEydRRRwqE
Old 01-26-2023, 08:58 AM
MrWrestlingII's Avatar
MrWrestlingII MrWrestlingII is offline
Here’s a pic of 275/60/15s on a 15x8 rally II with 4.5” backspacing. I had the wheels custom made in the mid 90s.
Name:	Moog 5385 .jpg
1970 GTO-vert, 461, eheads, stump puller, m20, 3.42
Old 01-26-2023, 09:21 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
No problem running 275/60/15s on 15x7s, I've been doing it since 07. 15x8s would be ideal, though. Your car is beautiful, is that Liberty Blue?
ID:	606067   Click image for larger version
Chris D
69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60'
Old 01-26-2023, 09:24 AM
OCMDGTO's Avatar
Sorry, meant to add this pic
Chris D
Old 01-26-2023, 09:21 PM
tremo's Avatar
Excellent news! That's what I was hoping to hear. I think they look good on 15x7s, not bulged at all!
If others have more pics, please feel free to share.
The color of my Custom S is more like the first few pics, especially the third pic. It's not Liberty Blue (although I love that color!), it's some other GM color of some sort?? It's got an "Earl Scheib" paint job from 17+ years ago from the previous owner = looks great from 20', but definitely has some orange peel. I swear, for some reason, it seems women really love that color! Can't tell you how many compliments I've gotten over the years. The last pic came out darker for some reason when I edited it to zoom in more.
P.S. Let me try to re-attach your pics with the correct orientation. The site did the same thing to me last night = wonky. Also adding a pic that is more representative of the color.
ID:	606096   Click image for larger version
ID:	606097   Click image for larger version
Old 01-26-2023, 09:53 PM
tremo's Avatar
Would love to see more pics of your car fully painted! I'm intrigued by your sig:
69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.64@ 114, 1.59/ 60'
The Following User Says Thank You to tremo For This Useful Post:
Old 01-27-2023, 10:08 AM
Half-Inch Stud's Avatar
I tried the 275 s on the rear about 30 years ago and the handling in turns became high oversteer.
So the decision was 245s all around, and that takes some front fender-tip (and stainless-tip) trimming for best results.
I suppose the 235s on the front, and something bigger in the back is what everyone else uses. Naw, meh, no thanks.
Old 01-29-2023, 05:35 PM
OCMDGTO's Avatar
Here's a couple, car looks really dark in low light
ID:	606308   Click image for larger version
ID:	606309   Click image for larger version
Chris D
