EFI Tech All things EFI and making classics modern!
Old 11-22-2022, 08:43 PM
R 70 Judge's Avatar
Default Learning to tune Holley EFI courses
If you are interested in learning how to tune Holley EFI, Joe Simpson of Tempest Racing has made easy to follow courses. He is running a Black Friday special this week and it only costs $249 - Black Friday link https://www.tunethetrilogy.com/blackfriday22
I bought the course myself. He explains things at a basic level for beginners and keeps things light and funny.
Here is his YouTube channel: https://www.youtube.com/c/JoeSimpsonAtTempest
What's Inside Tune The Trilogy?
-Learn Holley EFI, Terminator X, & Sniper Software From Top to Bottom
-Learn How to Data Log & How to Make Adjustments From Analyzing The Data
-Learn How To Build Fuel Maps, Ignition Maps, Target AFR Tables, Cold Start, Idle, Boost Control, Nitrous, Flex Fuel, Custom Tables, ETC.
-Cause and Effect Walk Through Examples Using Mainline Pro Hub Dyno
-Access to Private Facebook Group Community For Technical Support & Conversation. No Public Group Nonsense!
-Beginner, Intermediate, & Advanced Users Can All Learn, Even If Your Car Has Already Been Professionally Tuned!
-Guest Appearances With Other Holley EFI Tuners/Instructors
-Online Format: Watch As Many Times As You Want
-Far More Content Than Could Ever Be Covered During in Person Training (We Still Suggest You Attend Those As Well!) - This Course is Typically Far Cheaper Than In Person Training Once You Factor In Travel & Time Off Work ETC.
-Continuous Updates & Content Added. Use the FB Group to Discuss Other Content/Info You Would Like To See Covered!
James
1970 Trans Am
Spotts Built 484" IA2, Highports, EFI Northwind
Terminator X sequential EFI fabrication and suspension by
Old 12-12-2022, 11:09 AM
djustice's Avatar
djustice djustice is offline
I have followed his youtube channel for about a year, his basics holley beginner videos have been very helpful for getting a grasp on tuning, as well as his dyno tuning videos on where to start and increments of adjustments etc.
Murphy's law - "Anything that can go wrong will go wrong".
-469 ,Butler 310+ Eheads, Hurricane intake portmatched by butler, Butler roller 230/236 @0.50 112 LSA, Johnson lifters, pypes 2 1/2" exhaust, 3.42 yukon duragrip lsd, holley sniper efi, hyperfuel efi tank +++
Old 11-24-2023, 12:26 PM
R 70 Judge's Avatar
Black Friday sale is on! $297 for the next 12 hours
https://tunethetrilogy.com/blackfriday
James
1970 Trans Am
Old 11-24-2023, 12:31 PM
R 70 Judge's Avatar
James
1970 Trans Am
Old 11-24-2023, 11:58 PM
yellow1098's Avatar
yellow1098 yellow1098 is offline
I purchased the course based on your recommendation judge it’s awesome…thank you!
The Following User Says Thank You to yellow1098 For This Useful Post:
Old 12-02-2023, 03:47 PM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
Damn it's $597 now, what a deal that was.
The course looks and sounds great, would really help the fear of destroying your ride and needing to rely on a tuner every time there's an issue etc. I think I'll still join, possibly convert my other cars to Holley later on if I really get a handle on this.
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp - 93 oct at 34 deg (207psi)
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10" 0 Stat, Ricks SS Gas Tank, Magna 4303, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" Headers & Borla Pro XS 3" Muffs, Alum Rad & Dual Fans, 12:1 Box, UMI Control Arms & Viking Berz Fr + Rear CO Shocks, Hella UP28 Vac Pump
Old 12-12-2023, 09:29 AM
Formula8's Avatar
Formula8 Formula8 is offline
I picked it up on the Black Friday sale as well. I was surprised to find the discount code on Youtube worked in addition to the BF sale. Ended up paying $267 but haven't had the time to start watching
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi.
The Following User Says Thank You to Formula8 For This Useful Post:
Old 12-15-2023, 01:23 AM
R 70 Judge's Avatar
That’s even less than I paid and I was in as soon as he released the program.
I did get a free upgrade to the “Live Tuning” add-on. I haven’t checked it out yet. Been too busy with work and Xmas stuff.
James
1970 Trans Am
