Old 06-11-2022, 05:59 PM
GTOLou GTOLou is offline
Default shaker - flapper.
How many of you guys put one of these in? Seems like a weak spring and vacuum opens it.
https://www.ebay.com/itm/25551855270...53.m1438.l2649
Dude has sold a fair amount w/ good feedback on them..anyone??
Old 06-11-2022, 09:59 PM
The car I just purchased already has one but it isn't working - neither is the car but that's another story...
I'm hoping to set something like this up however. Hopefully a small bird doesn't get sucked in there...haha
Old 06-12-2022, 03:43 PM
pontiacstogo's Avatar
pontiacstogo pontiacstogo is offline
Yep - I'm running one on my 74. The thing I liked the most about it was that I was able to remove the old block off plate and install it without any modifications to the shaker at all i.e. it's reversible if needed.
Opens fine under mid to full throttle and allows for a bit of intake 'roar'. Probably makes little to no difference in performance, but it's much cooler than having the shaker opening completely blocked off.
Peter
1974 Trans Am, 400 4-speed, 3.42 rear.
The Following User Says Thank You to pontiacstogo For This Useful Post:
Old 06-21-2022, 04:06 PM
glenn911's Avatar
glenn911 glenn911 is offline
My 74 shaker was already cut out, so I put one of these in and it works great. opens and closes with engine vac. He also had a kit that would make it open via a switch and plunger set up.
Old 06-21-2022, 06:54 PM
burd's Avatar
burd burd is offline
I put black screen in, open all the time. Y car doesn’t see rain.
🧩 Burds Parts, Finding those Hard to Find PCs, no Fisher Price Toys Here
Just Say No To 8” Flakes pause pause
F ire B irds
Old 06-21-2022, 08:11 PM
Brentco's Avatar
Brentco Brentco is offline
I don’t even have screen in. Wide open. Never been an issue. Even during the years the car was my daily driver in Portland.
I thought the block off plate was mostly about responding to noise regulations? I don’t see rain or other stuff getting through the opening in the shaker to any problematic extent..
1976 Trans Am Buccaneer Red
468ci, 10.5:1 CR, 87 CC RPM CNC e-heads, HR 282/288, 230/236, 561/.573 lift, Johnson Lifters & HS 1.65 Rockers
Old 06-21-2022, 10:22 PM
burd's Avatar
I like the look of the screen, actually gutter gourd. Looks stock from a distance
F ire B irds
Old 06-21-2022, 10:35 PM
FrankieT/A's Avatar
Its gotta be worth a shot at $50 bucks to your door...
Old 06-21-2022, 11:39 PM
So cool...almost as cool as the third Gen turbo lites...
Old 06-22-2022, 08:05 AM
burd's Avatar
Or like lights in the wheel wells
F ire B irds
Old 06-22-2022, 12:11 PM
I just bought one. Someone opened the scoop on my SD decades ago.
1974 Formula 400 - Ram Air automatic
Old 06-22-2022, 02:42 PM
scoops are meant to scoop...even if they are a$$ backwards...lol
