2" headers in my 69 with highports
Stock frame 1969 gto with highports, looking for a reccomendation on a set of 2" headers that I don't need to beat with a hammer. It's an automatic as well. I have a ministarter and shaved firewall with no ac. Do the Doug's 2" headers fit well?
1969 GTO street strip project 11.1 forged 461, highport heads 1995 Trans-am 420 ci sb 14:1 compression 9"ford 9.89@132 1.34 60ft SOLD! |
Also running mity mounts and I don't want to raise the engine as hood clearance with my northwind would be tight
I put 2" Doug's in my brother's 1970 LeMans street car with RP Eddy heads and a 4 speed, there were some tight spots but they did not require any hammer work.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
Do the highports have a different height on the exhaust exit then the edelbrocks?
No.
Doug's are always our "go to" header.
I may have to try them. I think coated versions are close to 900 now. .
How much is it to have some headers coated ? Have a sweet set of 2" Dougs, slip collectors. Weld in 02 bungs and coat them.
Not sure hiw much coating is now. Butler has 2" bare steel Doug's for 599 though. I'm thinking it would be at last 400 with shipping to coat
I have Mad dog 2" headers on my 71 that I used with eheads and Hiports.
A new best of 9.135 @ 145.41 71 Lemans Sport. 72 Lemans Sport. |
Good to know. I heard Maddog headers were great but hard to get a hold of? Wish I could go that route
I think here at PolyDyn coating header is around 300+. And I can drop them off vs shipping charges.
I would get bare headers, mock up and then get them coated after installing an O2 sensor bung in each collector. It cost $250 to get my brother's headers coated 3 years ago at a place in NH. I run Mad Dog headers on my '68 FB race car and the fit is very good even with 2". I just bought some from Maddogs last year and I have his number if you want it.
I think it's Direct Coating in Concord, NH, I'll try to look for my paper work. They are an hour from me so I drove the headers up there.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. Last edited by AG; 05-08-2022 at 01:22 PM. Reason: added text |
Thanks just ordered the bare steel 2" dougs. I will be doing some data logging so I will need o2 fittings
I built my own with flanges from Kre for my Highports. They are fenderwell exit headers, one is a slip fit. A place by Chicago coated them for about 150, but that was a few years ago.
Illinois Outlaw Gassers 6.27@107 9.97@131 |
Those look nice
Anyone ever needs 69 bird round ports call tubular automotive in mass they made headers for that car in the 60s and they fit very well, not sure about GTO but they are well known for quality stuff. My car had them
On it when raced in 69. Their catalog should be online. They made the headers for a lot of the companies that I see people buying from that charge more for them. Also a great resource is mad dog headers they just did a set of RAV for me for 69 bird and I was very happy with the headers.
Happiness is just a turbocharger away! 960 HP @ 11 psi, 9.70 at 146. Iron heads, iron stock 2 bolt block , stock crank, 9 years haven't even changed a spark plug! selling turbos and turbo related parts since 2005! |
Since you're in the race section, I would suggest Kooks headers, they are in NC. If they don't have an " on the shelf set" , they can build anything want...
