Old 02-06-2022, 01:03 PM
newmexguy newmexguy is offline
Default ';69 - '70 Englne bracketry
Bracketry found at / removed from a 400 engine in a Catalina. Unsure of what exactly all it fits, as there were a lot of variations with the Pontiac bracketry. Am personally a Generalist, with a specialty in Chevrolet parts '69 up.
1. Power steering - aluminum bracket to head, with bolts (original) and stamped steel brackets to pump, and intake. Pump with single pulley,, no denting on pump housing. Personally, would clean and reseal pump, before use. VG original shape. $125
2. Aluminum AC bracket, believe went on passenger front, with two steel spacers. Found on ground, underneath the catalina. Appears identical to online brackets listing for up to $200 plus. $125, and will include two stamped steel brackets that are still with engine. Cast "H" shaped bracket that I believe is needed, for lower compressor mounting, is not present. $125
3. Original water neck, an online search defines it as '65 - '70 apps, this one is super clean and not eroded. $25.
Everything above, for $225 plus shipping.
ID:	583598   Click image for larger version
ID:	583599   Click image for larger version
Old 04-03-2022, 11:37 AM
Default 69 - 70 Pontiac PS pump, and ALL engine bracketry
Update, went back to this yard, and stripped the engine clean. Have pretty much everything bracket and bolt related from this engine. ('70 400, PS, A/C equipped). Have the two head bolts with the smaller threaded studs on top, also. And several bungs and fittings that go on the Intake itself. And the Carb throttle bracket, the spark plug wire looms, and more. All of this is ORIGINAL GM.
Old 06-01-2022, 06:21 AM
Default 1970 bracketry
to the top
dave s
Old 10-06-2022, 07:46 AM
Default 69-70 bracketry, and PS pump
To the top. All brackets, and a PS pump from same engine. (70 400) Cleaned and tumbled by local machine shop. All grime and gunk removed.
Dave S
Old 11-05-2022, 10:29 AM
Default Bracketry, '70 400
To the top. Selling as Package, unless someone wants top of engine doo-dads only. Dave S
Old 11-28-2022, 08:32 AM
Default Sold
This entire Lot has been sold. Dave S
