Old 12-18-2021, 07:16 PM
eodcoduto eodcoduto is offline
Default New member from NW Alabama
Hello all,
I've been out of the Pontiac game for a long time but I finally brought my high school car home after 23 years. I bought my '74 Trans Am in 1995 when I traded a 1970 LeMans Sport for it. Should have kept the LeMans, it was a factory 4 speed and had a '69 428 in it but the shaker got me. I drove it for a few months then late one night the engine locked up on me. It took two summers to get the cash scrapped up to rebuild it and when I did I got 500 miles out of it when coolant got into the oil. This was right before graduation and I went into the Marine Corps soon after. The car sat and my brother robbed parts off of it for years then it was sent to the tree row. At some point I sent money home to get the engine rebuilt and that was about 20 years ago, its never been fired up.
Now that we are settled I went home and picked it up. The engine, car, and transmission were in 3 different spots so we borrowed the neighbors loader, lifted the engine, bolted up the tranny and dropped it in the car, in 23 minutes. The motor mounts are gone from the car and the '69 block needs adapters but that will come.
Plans now are to tear down the engine and get it magnifluxed, I have a suspicion there is a crack in the #4 cylinder. If the engine is good I'll fire it up and see what happens.
I will need the front bumper and a ton of small parts that were robbed off to get it on the road. Might just go Vice Grip Garage and make a burn out car.
Sorry for the long post, but having this thing in my shop has been a long time coming.
ID:	579950   Click image for larger version
Name:	Trans am loaded.jpg
Last edited by eodcoduto; 12-18-2021 at 07:20 PM. Reason: Picture rotation and size.
The Following User Says Thank You to eodcoduto For This Useful Post:
Old 12-18-2021, 07:51 PM
thepontiacman's Avatar
Good Luck with your Trans Am.
I'm located in Talladega AL.
thepontiacman@yahoo.com
Sent from my Moto Z3 Play using Tapatalk
The Following User Says Thank You to thepontiacman For This Useful Post:
Old 12-18-2021, 08:48 PM
1_Wild_Cat's Avatar
Good luck…glad you are rolling on your project. Keep us posted on your build.
Old 12-18-2021, 09:17 PM
Do you have a bunch of parts posted on Craigslist? If so I talked to you the other day about your 455's and some other parts.
Old 12-19-2021, 12:06 AM
Welcome to PY good luck with your Pontiac.
'68 GTO
'69 Corvette
'75 Cadillac Coupe Deville
TOM
Old 12-19-2021, 12:18 AM
Welcome aboard!
Dr. Thomas Sowell
Old 12-19-2021, 08:33 AM
David Jones's Avatar
Welcome.
Pleasant Grove Alabama here…..
Old 12-19-2021, 09:18 AM
Half-Inch Stud's Avatar
Welcome! 68 GTO, Guntersville
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct
Old 12-19-2021, 09:53 AM
Yes, I am the one you called from CL ad. I have a few parts.
Will see if I can help you with your TA parts needs.
Old 12-19-2021, 11:16 AM
einstein's Avatar
einstein einstein is offline
Welcome from a Yankee transplant here in the other LA, lower Alabama. Near Ozark.
There's a guy near me who has about 30 second gen parts cars, but he's not on these boards. I'll try to find his contact info. He usually advertises on CL.
Old 12-19-2021, 05:15 PM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Cool car, good luck! You have your work cut out for you
Chris D
69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60'
Old 12-19-2021, 07:11 PM
Yes I do.
Old 12-19-2021, 09:47 PM
I have forgotten what the High Country / WT5 option consisted of.
Couldn't have been much since it was no-cost.
Believe it was for high altitude areas.
Also quite unusual it is even listed on the invoice , since it was no charge.
Very neat factoid to get more details on from other members.
Welcome to PY Forum
Best wishes on getting the TA back into one solid piece
Old 12-19-2021, 11:03 PM
The high altitude sticker is still on the driver’s door, but my biggest search is the cordova top. Its not on the option sheet but it was on my car when I got it. I’d like to know if its original.
Old 12-20-2021, 01:10 AM
Trim tag data on the cowl will tell if it was built with vinyl top.
Noticed it looked like it had one at one time, but not on the invoice.
It was an available option on a 74 TA , and we have seen some rare cases where a certain content isn't listed on invoice - by mistake.
It WILL be on the trim tag if it was installed on the assembly line.
Old 12-20-2021, 01:15 AM
On a 74 F-Body car
Factory top , the studs that hold the clips in place for the moldings to attach - will be spot welded in place.
Aftermarket top - the clips will be held by rivets or screws.
Old 12-20-2021, 08:13 AM
The top was taken off by a local kid years ago while I was deployed, I’ll wire brush his body filler and see if there are holes or signs of studs. Here is the cowl tag.
Old 12-20-2021, 12:22 PM
29 - 29 PNT is the lower and upper paint / trim codes
So it was painted dark blue complete.
Vinyl top car would read 29 - A or 29 - B for examples
Factory vinyl top cars will always need some additional body work at the roof-to-quarter panel seams to get them smoothed out enough for decent looking repaint.
I had a dark blue 74 firebird in the mid 80's with white vinyl top and interior.
Removed the top and prepped it for a solid repaint.
2nd gear went out and I parked it before I got around to painting it, then eventually sold it.
