67 Convertible Sprint? on Ebay
Good looking car, very base model with Manual Brakes & Steering, 3-Speed manual trans, & Base interior. Seller (dealer) says it has a later engine so I am assuming a 68 250 OHC-6. But they also say it has a 3-speed "Top Loader" and I clearly see the external shift linkage & rear counter weight that to me says its a 3-speed Saginaw. The seller does provide alot of photo's and 1 Video
Also interesting routing of the thermostat bypass hose! I have never seen it go around the rear of the engine before. Holley Carb, looks to be a 66 Sprint or Air Cleaner. And does the car have seat belts? I do not see any front seat retractors? https://www.ebay.com/itm/12503156352...=10001&mkevt=1
Jeff R 60 Jaguar Mark 2, 3.8L Automatic 67 Sprint Firebird 230 OHC-6 4-Speed A/C 78 Catlina Safari, Pontiac 400 powered 77 Astre Formula, 215 Buick V-8 T-5 73 Lemans Safari, 400 4bbl 4-speed 71 Catalina Enforcer, 455 4bbl 06 Mallet Solstice #024 LS2, Now with a Tremec 6060 6-speed! 2012 F-150 Echo Boost (My local Ford Dealer SUX!!!) 2020 Dodge Charger Scat pack (recovered) Last edited by camerjeff; 12-06-2021 at 11:09 AM. |
Lots of little Wrongs on that one.
What's the deal with right at the floor pan at the tail end of the trans? Looks poorly repaired??
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. |
The baby blue top is an odd choice. I think white would have looked better.
I also agree that I am unsure about the choice of top color. White probably would look better.
Jeff R 60 Jaguar Mark 2, 3.8L Automatic 67 Sprint Firebird 230 OHC-6 4-Speed A/C 78 Catlina Safari, Pontiac 400 powered 77 Astre Formula, 215 Buick V-8 T-5 73 Lemans Safari, 400 4bbl 4-speed 71 Catalina Enforcer, 455 4bbl 06 Mallet Solstice #024 LS2, Now with a Tremec 6060 6-speed! 2012 F-150 Echo Boost (My local Ford Dealer SUX!!!) 2020 Dodge Charger Scat pack (recovered) |
Dual exhaust set up is interesting. I thought about it initially for my 69 Sprint but I couldn't see how there could be room around the clutch linkage for two headpipes.
My Break Away Squad 1969 Fbird (base OHC, 350, 400HO & Sprint Cvt’s - 400HO & TA ht’s) 1969 Custom S 2dr ht 1969 LeMans (2dr & 4dr ht & Cvt) 1969 LeMans Safari wagon 1969 GTO (2 Cvt, 2 ht & Judge ht) 1969 Cat (3 Cvt’s & 2dr ht) 1969 Ventura wagon 2 seat 1969 Exec 4dr post 1969 Bonnie Cvt & 2 wagons 1969 Bonnie Brougham (4dr ht & Cvt) 1969 Grand Prix 2 SJ’s 1969 2+2 2dr ht (Canadian) |
Sounds like the 68 Firebird I had. One barrel carb, three speed saginaw, maybe one option. Thing I paid like $500.
Why is the late (250cid) more desirable than the early (230 cid) ? 230 had a grand higher redline. ps really do not want duals on an inline six unless have a really wild cam, scavanging is about perfect with equal length pipes and is lost with duals. |
I had a dual exhaust fabbed for a 69 OHC6 A/C coupe I had and saved the system to put on my Sprint convertible. Was a bit on the loud side and I had to add chrome tips to extend the outlet past the tail valance to minimize the noise in the car. Many folks said it sounded like a V8 when idling, even when goosing throttle a bit, but above 1,500 it got very distinctly sixey.
