67 Vent Windows Glass Installation
Has anyone replaced the glass without taking the entire window assembly apart?
Thanks DM3
IG: #67MoparBird (Follow my rebuild) 1967 Firebird 400 Appeared on Gearz, Season 16, Episode 1, Segment 'What Are You Working On?' |
The main window front track and vent window frame are all one assembly. You need to remove the door panel and front track assembly. Then drill out rivets in the frame that hold the vent window frame triangle together. You can replace the rivets with small bolts. If you support the window in the door you can probably remove the track without messing with the regulator.
Thanks!
